Shorter Stem - My Experience
cd365
Coventry, uk
After 9 months off my bike due to a calf problem (I'm still waiting for my NHS hospital referral, I went private in the end) when I got back on my bike I had a relapse, serious pain in my calf again. I gave it a couple of weeks and tried again and decided that maybe I was over-stretching a bit. I've had the bike for a few years and always seemed fine before.
After a bit of research I decided to try a shorter stem, so I went from a 100mm stem to 60mm stem. I have now been riding that for a while and have had no recurrence of my calf problem. One of the problems that I read about on here of moving to a shorter stem was the bike being a bit more twitchy, I can honestly say that I haven't noticed. I can still ride no-handed uphill.
So in my experience if you want to try a shorter stem, give it a go, it might not be what you want in the end but it is worth trying. For me it has had the desired effect.
cd365
cd365
Coventry, uk
How would stem length relate to riding no hands?
Because people said the bike could be more twitchy. I used riding no-hands to test if it was.
Why do you think it helped the calf problem? What did your private consult diagnose out of interest?
Levo-Lon
Twitchy with a shorter stem applies to inputs you make..
but if it solves your pain its not an issue..
i run a 80mm stem as the 100mm just caused me shoulder pain.
cd365
cd365
Coventry, uk
The common perception that a shorter stem increases twitchyness is because a given amount of hand movement leads to a greater amount of rotation of the forks than with a long stem. Hands off, it is going to be no different.
I'd noticed no difference hands on so tried hands off as well. Thought it worth mentioning.
GrumpyGregry
Here for rides.
Shorter stem twitchiness is exacerbated on wide bars. Me? I like a longer than "normal" top tube and nice short stem. On drop barred tarmac bikes I ride on the tops most of the time and I've never encountered the twitchy. On a wide barred mtb with shortie stem? Oh yes.
Loch side.
It will be different. The bars and front wheel flop around more with a longer stem than with a shorter one.
