Biff600
Now I get your avatar![]()
Oh no, that pertains to my previous job of gunnery and drill instructor
You might be interested in what I do at work.
Nice!
I'm mapping a lot of footpaths at the moment, so most of it is done on foot. A little low tech, but at least I get to go for some nice walks!
.Are you all sitting down.
CBR 900, service and strip clean and setup carbs (been stood 4 years). Ran like a dream afterwards and enjoyed working on it.
View attachment 408714 View attachment 408718 View attachment 408719
2015! CB500, should have been an hours job for chain and sprockets but front sprocket seized onto output shaft. Had to get some heat into it with our "stick" welder while loading it up with the hydraulic puller..
ZX6 valve clearances (all 16 out of spec!), lot easier to a loose engine though!.
GTS 300 User Rectifier replacement, could have made it more accessible..
Pan European for seals, had to pull the front end out in one lump and get the gas torch on the legs as the seals were seized into the legs.
Hell man you're worth your weight in gold, don't suppose you would relocate to France and service my Ducati 748s
Yamaha MT09, fairing and radiator off plus clean air crankcase breathers off to access blood spark plugs, then another hour just to get to air filter....
GTS 125 fuel pump replacement, had to drop the engine off it's mounts to pull fuel tank down enough to replace pump.
Triumph America (2015).
Multiple wiring faults and Canbus failure, still on with it as I've had to strip the complete loom finding broken wirs and crimps as I go, lovely..
