So I've done it and gone down the silca chain waxing system, was already considering it before this thread started . 1st ride today on a new waxed chain treated with the strip chip whole process is simple enough . A question the chain that has been replaced has 2700 miles on it but shows minimal wear and has been run on Silca super secret drip on wax after stripping the factory grease with solvents ,is it worth waxing this chain and would you use another strip chip to completely clean it
The first ride was quieter than I expected ,I had losened the links by hand and then ran then over a bar to articulate the links
I’m 3-400 (?) miles into Silca Secret Wax 2 (Drip application) on my Carrera. And generally REALLY like it.
I completely stripped the chain (Removing it, soaking in White Spirit and brushing etc to agitate). *Someone here mentioned not worrying about cleaning 100% as it’s Not an F1 car. Well I to hate to break it to ‘you’ but Oil and Wax don’t mix. So whatever Oil was left on - is going to help your fancy new Wax run off…….🙄
I thoroughly cleaned the cassette / removed and cleaned jockey wheels / rest of drivetrain. Rinsed; and once all dry: did 3 applications over time - to layer the Wax up.
Normal stuff upon first riding: Quiet, smooth, great gear-changes. And after 100-150 miles I could start to hear the difference as a first sign the lubrication was degrading. Much the same as any of the very best oil based lubes I’d tried…….
BUT - the wipe down, (Not really cleaning to any great degree) and re-applying of the Silca Drip-Wax was 10 times quicker and cleaner than with Oil. And THIS was what I wanted. So much of my time previously being ‘wasted’ cleaning up after rides…..
I’d be really interested now you’re going to immersive - from Drip - to what degree you feel any gains ? Either whilst riding, in applying, longevity or anything else……
Good luck
