Smurfy
Naturist Smurf
- Smurfette's Kitchen
Check out the chain angle for both of those. I'm guessing that neither will be perfect. If you normally use the lowest gear to climb, maybe best to start with 50-21, as it is slightly lower than 34-14, and also has the advantage that larger chainrings and sprockets wear slower than smaller ones. The only down side is that it will be a bit spinny on the flat. If you find it a bit of a slog on the hills, don't be put off straightaway. The extra strength builds quite quickly in a few weeks.34&14 or 50&21 according to the calculator for 65"
] before your pedalling technique becomes smooth enough to handle very high cadences. My record in km is 71, not something I would care to repeat any time soon! I see so many cyclists "pedalling squares", really awful waste of energy, riding fixed soon cures that!
