Small wheel disc braked dynamos
chriscross1966
Swindon
Hi folks... I'm looking for info on 100mm wide disc-braked dynamo hubs suitable for small wheels.... I know of a couple, an eye-wateringly expensive SON (it will be lovely, but it is expensive) and the Biologic Joules 3 Disc.... which isn't exactly cheap and seems to be almost unicorn rare ATM.... so are there any others?... needs to be double-sided not single....
If I can't find one there are any number of cheap bigger wheel units kicking around, what are he issues with running a dynamo intended for bigger wheels on something with a 349 rim?.... Thought I'd ask here as bents tend to smaller wheels at the front and are way more likely to be disc braked than the folder I will be fitting it to...
TIA
chrisc
raleighnut
On 3 Wheels
TIA
chrisc
I think the 100mm OLD might be a problem.
YukonBoy
The Monch
Inside my skull
Why not look at one of the Shimano 1.5W rated dynamos? With the faster spinning of a small wheel they should generate the higher watts you'd want for a front LED light.
