Snapped spindle
Status
Not open for further replies.
silva
Belgium
Replacement HT2 bottom brackets are typically £15. The OPs crankset has cost them approx 0.3p per mile. It is hardly mega bucks.
HT2 installation is typically 2-3 times ST cost.
No replacement is typical £0.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Nope, unless going for the latest and greatest 11 speed or something. It’s simply not that expensive. You’ll pay 5 times as much for a smartphone that won’t last as long. You’ve clearly been looking in the wrong places at something you hsve already discounted anyway.
  • Like
Reactions: C R
R
roubaixtuesday
self serving virtue signaller
Yes, it was exactly £15. They're cheap and easy to fit. But of course it wasn't the BB that was the issue (I could probably have rescued the BB if I'd really wanted to)
  • Like
Reactions: C R
R
roubaixtuesday
  • Like
Reactions: C R
wafter
Oxford
In the middle of the arm. It's a long time ago, but as I recall it was a classic fatigue failure; you could see the original flaw and then the crack having slowly propagated from it.
Google tells me that failures of either arm or spindle at the interface are a thing.
Happened literally right in front of a bike shop who I still suspect of having a crank death ray destroyer gun to boost business, taking aim at unsuspecting passing students.
lol - at least it was convenient!
Yes; sounds like the flaw was to blame if the failure was in the centre of the crank arm since the bending moment would be higher at the BB spindle, so assuming the arm wasn't slimmed excessively in the middle the flaw was significant in causing the failure.
Regardless of where it failed a knackered crank can't be a pleasant thing to deal with and you likely did well not to come off :smile:
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
you mean, to remove Half of Hollowtech 2?
Nope the whole of the crankset. You clearly have no experience with HT2.
silva
Belgium
Latest greatest not that expensive 5 times as much,
... are no numerics.
I'll give you an example:
On 28 august 2024 I bought 2 square taper cranksets here:
https://cnc-bike.de/sturmey-archer-singlespeedkurbel-fct26-silber-p-14173.html
38 euro each.
1 to mount directly on the replacement frame (old broke) as a return from Octalink 1 crap to square taper
1 as a spare.
... also a real example.
Can you also put a numeric on your HollowTechnology2 crankset?
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
38 euro each.
1 as a spare.
Here you go. €44 for both cranks Hollowtech in single speed as you have chosen. Cheaper than your example. Me thinks you make a fuss about nothing.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Do you?
Because when the Hollow Technology 2 bearings of my previous bike failed (alot play) I saw the dealer needed a chisel and a hammer to get the other half (driveside) loose.
Yes because the crankset is not the bottom bracket. The bearings are in the bottom bracket. But even with a HT2 bottom bracket; if you are using a chisel and hammer, then you are a crack handed buffoon.
silva
Belgium
Me thinks you just pickpecked a cheapskate nonamer.
It's even unusable to me since ring has a max 38T.
Material likely also 6061 instead of 7075.
My example https://cnc-bike.de/sturmey-archer-singlespeedkurbel-fct26-silber-p-14173.html
37.95€​
- Sturmey Archer Singlespeedkurbel FCT26 silber 46 Zähne
- Kurbellänge: 170mm
- Lochkreis Kettenblatt: 130 mm
- für breite Ketten 1/2" x 1/8"
- Material 7075 Aluminium
- für 4 Kant Innenlager JIS (Shimano o.ä.)
- Farbe: silber
- Kettenlinie bei Innenlagerlänge 103 mm: 43,5 mm
- Gewicht: 730g
... has also a 1/8" chainring
What are the full specs of the set you just showed the sales header of?
Status
