DRM
- West Yorks
Nowt wrong with a scooby snack or two,Blimey, this thread has turned into a mountain rescue ad, I would add a chocolate bar or flap jack, high energy boost
Surely Kendall Mint Cake ??
They have, Emergency Call Roaming, since 2010.thanks for that - good to know - why don't they do it for 999 as well though? (maybe showing my age)
If you can't read a map, how would you manage with Google maps, or any electronic map?You can save Google map areas to your smartphone. So you'll have a location provided you have a battery.
A map is great but only if you know how to read one.
3 blasts, short break then 3 more, @Drago would be the man to know for defo.Yes six blasts on it if iirc, also the other mention of survival bags and woolly hat, gloves, warm lightweight jacket etc are top tips, you might not need it, but you could stumble across a Walker or cyclist who does, if going really into the hills don’t forget that it may be lovely and warm lower down, but winter conditions can sneak up on you in a flash in the hills, a frame bag to put it all in is a good idea, you could also take a hexy stove and a metal mug and some 2 in 1 or 3 in 1 coffee sachets so you can make a hot drink if needed
According to Online Scout Manager, it's both or either.3 blasts, short break then 3 more, @Drago would be the man to know for defo.
Just some additional guideWhy not get this if off track is a regular thing. Emergency SOS via satellite. It also sends a regular location pings to your other half so they know where you are. Can be used Worldwide.
https://buy.garmin.com/en-GB/GB/p/592606
I think there's some confusion here, there are two different systems. The PLB and trackers, with the PLB you don't need a subscription. You just register them with the coastguard. Once pressed it sends a SOS and your GPS coordinate, nothing else no two way messaging or tracking. You do have to get the battery changed every six years. (£180).Just some additional guide
1. Do not need subscription in the UK or Globally to activate the SOS button which is on the right side bottom. As it is satellite based does not need phone / wifi signal. Just a single outlay of £300.
2. There is no need to punch in any coordinates or scroll thru menu, just press the button.Emergency Services will take care of the rest. Remain in the same spot and if you move for shelter, do not switch off your device.
3. Many of us struggle with tech, then important to provide ETA and route map. Do not deviate from route even to explore to few metres away down. Don't bother with route update as there is no signal. Route updates are essential for touring where signals are available when you reach small towns even in remote regions.
4. If you argue that this device is useless if you are concussed or fall unconscious you are right. But it also says a lot of about how logic and common sense is applied.
What the device does is provide peace of mind. You do not have plan the route ahead, you can explore, extend your stay etc. The family does not have to carry the burden of understanding maps and routes for every ride.
I came to know a chap who runs a small business with his wife in Durham. He often heads to Pennines during off peak which is wonderful place with lots of established trails of varying degrees. Bear in mind even the carparks have no signal.
The map tells you where you are. Makes things a lot easier.
I'm expecting that there's some ability on the part of the lost rider.Well given the OPs posted route Google would just show you are in a blank space between roads. Since you can’t read maps you won’t know which direction the roads are or whether they are small or big or how to reach them or whether there are any walls or cliffs or boggy ground between you or them.
