'Speed Dreams : Fastest Place On Earth'
TVC
It was very good, proper engineering.
It looked a bit Heath Robinson to me.....is that proper engineering?
For, as Fred Dibnah, famously called it 'Back Street Mechanic-ing', I'd say it was spot on
After all, everything had to be scrutineered before acceptance, & they'll have very high standards, due to the speeds/fuels involved (ie; the Methanol fuelled contenders)
screenman
My kids 41, 36 and 26 all enjoy cycling, along with having the enthusiasm to go with it. So to say it is not passed down is very wrong in some cases.
Levo-Lon
My first experience with cars was changing all the ht leads around on my dads p5 3.5 rover circa 1970 ish ..he seemed to be a little confused as to why his car sudenly didnt work.
and my sister painted his 650 bsa with a tin of council green gloss ..lol..
Loch side.
Green is in the eye of the beholder. It was Racing green, wasn't it?
Loch side.
Here is one I made, not in my bag garden but at work a few years ago:
That is a beautiful piece of work. But what are we looking at? An engine block made from scratch? CNC'd from 3 solid blocks?
What was the application for it? And finally, why do it if you can simply strip a V10 from a BMW and perhaps modify that if you have to?
Are the pistons and valves and other components then custom made too?
The engine was going to go in a prototype car, but was never all finished. It was a V10 that was going to produce 600hp without turbos. All the exterior parts were completed on the engine but not the internals, but they were based on existing pasts that could be modified and used.
The cylinder heads were machined from 1 piece and then an insert was put in the top and welded in place to make it all water tight while the cases themselves were from one piece.
