SS Build - Help Needed - PLEASE
Not really - you slide the drive side back to tension the chain, then slide the non drive back to align the wheel. With a fixed you tend to 'walk' the axel back.
If you get the wheel aligned right bang on middle between the chain stays (rim/tyre in the middle) - i.e. at the bottom bracket, then check to see if the wheel sits bang in the middle of the brake bridge - if it doesn't then you need spacers if the wheel won't align.
gb155
gb155
Fan Boy No More.
Manchester-Ish
Ok mate - thanks - will fettle later
Gaz
gb155
gb155
Fan Boy No More.
Manchester-Ish
Can't get my head round this
This is how it looks after being fixed in place , having tightened the drive side first
The axel only just pokes through the drop outs when not tighten , when one side is tightened then the frame needs to be squeezed on the other side a lot to get the axel into the drop outs and the nut on it
Axel
Drop outs
This causes my chain line to FAIL :-)
Rohloff_Brompton_Rider
Formerly just_fixed
gaz, can you take a picture without the wheel in? down the length of the bike, just so we can check the stays/frame aren't twisted.
edit: then with the wheel in but not tightened.
Looking at the picture, it looks as though the non drive side does not have enough spacers in. It looks like the wheel is dished to be in the middle of the hub, but if you measure the end of the cone nuts to the hub flange, it looks from the picture that there is more space on the drive side - both should be the same measurement- end of cones to hub flange.
Formerly just_fixed
fyi,
my brommie has an offset dishing to allow for the fold, so when i replace the rims (i build em myself), the 1st thing i do is make sure the chain alignment is spot on (i always remove the axle for a really good cleaning of the hub gears, no fancy verniers in my house...lol), THEN, i worry about dishing the rim to the offset, have i explained that right?
it's difficult to tell, but the frame looks twisted, this is probably because you are pulling the stays in more than usual. might be able to tell with requested piccies.
gb155
gb155
Fan Boy No More.
Manchester-Ish
Noticed the wheel on my carbon has this
So I gave it a go and bingo
So I assume I need a spacer thing - quick release also made it much more simple - can I change my other wheel to QR ? And is QR ok to use on a SS?
Thanks Edit : is this a good chainline too ?
Rob3rt
Man or Moose!
Manchester
Chain line is still off a bit, move it onto the next sproket.Also dont know if its just the angle but wheel still doesnt look right in the middle of the chain stays.
gb155
gb155
Fan Boy No More.
Manchester-Ish
With this wheel the angle can be moved - with the other it just can't
Can I add a QR to a SS ?
gb155
gb155
Fan Boy No More.
Manchester-Ish
[QUOTE 1478329"]Take it to your LBS. Fifteen quid will save you weeks of uploaded photos and questions.[/quote]
£15 or £160? :0)
I'd love to get the knowledge myself tbh - what would the lbs do ?
