Stiff Gear Levers
Mattk50
MattK50
Herts
Hi,
My gears levers are getting harder to move on my Trek hybrid especially the 1-3 levers, my thumb's struggling on rides! Without adopting my old non cycling habits of just squirting some wd40 at a problem then how do I fix this? I've started to find my way around my bike now except how the gears work!
Thanks
Matt
It may well be a case of squirting some wd 40 on the derailleur.Also maybe the cable needs replacing as there could be a buildup of crud in the sleeves
It’s a case of cleaning everything thoroughly. There will probably be some build up of gunk around the points where the outers and inners meet. recabling the whole thing ( inners and outers ) is the best solution, but if you want to avoid that, strip out the existing inners, give the outers a good old clean and lube, re thread the inners, carry on.
Ticktockmy
Plenty of Vids on Youtube on cleaning brake and gear cables, if your cables run throught the frame, they can be a Pain in the backside if you dont watch out how you do it, again youtube vids show you how.
ADarkDraconis
Cardinal Member
Ohio, USA
Does yours have grip shifters? I find mine are stiffer in general than the levers on my other bike. They may need lubing more often or something because of the design?
I just took back to the cycle shop who replaced the cable and opened up the gear lever mechanism to lubricate it. Now, it's back to normal, why they didn't do that on the service two days before I will never know!
Because you didn’t ask? They can work like that sometimes.
Don't squirt WD40 onto new gear levers, they come from the factory full of grease and the solvent will dissolve it.
London
Well I would if there was a problem with them. In my experience bike factories are not always as generous with the grease as you might think. I have restored some pretty much seized Shimano rapidfires to new with some quick wd40 or gt spray. Newer shimano rapidfires seem to be easier to take apart, less reliance on far too tiddly easy to lose screws.
I mistakenly dissassenbled a Shimano gear lever once. I think they have special jigs to hold all of the springs and levers in place.
I use spray lube to restore older bikes to working order. Gear levers can be picky about lube, std bike grease seems to gum up Shimano ones.
Ticktockmy
My gear shifters/levers did not have any grease in them but use PTFE or nylon type components which do not require grease or oil, indeed both would be detrimental in the smooth working of the units
Hi,
Thanks
Matt
Matt you don't say how old your bike is..................... Is it still under warranty and or do you have it regularly serviced, if so then throw it back at the bike shop and ask them to sort your problem out. If not then any of the above ideas might help.
London
On the ralidfires I have taken apart all the moving business bits were firmly held together in a single mechanism. Just had to be careful with the small screws holding the cover.
summerdays
Cycling in the sun
Bristol
What did they do on the service then? I'd normally expect cables to be checked/replaced unless I'd specified not to!
