Luckily, Audi in their wisdom have thought about this problem and given us something called *something* assist? this applies and holds the footbrake when you stop until the accelerator is pressed to pull away again when the brake automatically releases. Superb! Except the moment you take your foot off the brake after the *something* assist has engaged, the engine that was switched off by the stop/start springs to life as the footbrake is no longer pressed...…
You really couldn't make it up!This is my thought, also premature battery knackerdness. I also recon it's another emissions cheat ! My dad was a mechanic, and he's turned it off on his car.
My BIL has to pop his key in a 'Faraday' bag at home.
- I don't know if it is just an Audi thing, or maybe because it is an automatic, but to make the stop/start function you have to keep your foot on the brake! This is something I refuse to inflict on the drivers behind me. In the old days with a manual handbrake I would pull the brake on a few clicks until ready to set off again, but thanks to the wonders of modern tech we now have an electronic parking brake which won't release unless you press the foot brake first, therefore flashing your brake lights at the drivers behind when actually you are setting off, not stopping!
It is fitted to my wife's Audi and I turn it off for two very good reasons (three actually now I think about it).
- By far the majority of our driving results in it actuating when we are stopped for just a few seconds, usually just as we are trying to pull out of a side street. Not ideal!
- It hammers the battery, especially at night when the lights are on and fans blowing etc. The additional cycling of the charge levels is not good and drastically shortens the battery life, regardless of how fancy and expensive the battery is (and they are fancy, expensive things).
It just doesn't seem possible that, for instance, you are stopped at roadworks and have to sit for 2-3 minutes or longer with your foot on the brake for the stop/start to work. Am I missing something or is this just incredibly stupid tech?Mrs B's auto VW (obviously part of the same group) does the same. FWIW I can't get my head around the thought process either.
I’m not disputing that, just intrigued cos I hadn’t heard it before - how does that work?It's also bad for the brakes, promotes disc warping.
Alas, the correct use of the handbrake to punctuate a car becoming stationary is all but extinct.
I've recently replaced our car's battery after the beast from the east killed it with ice. I could have got it from Halfords except for the difficulty of driving a car without a working battery 3 miles... that and them charging 50% more for their own-brand than a big-brand one from our usual mechanic around the corner.and those that have a solo battery must have a particular specific battery which you won't just be able to trot down the Halfords to buy and have fitted by their work experience spode.
