aJohnson said:
I'll be there... well I should be. Need to get some more mileage in so this will be perfect.
trio25 said:
Sounds great!
aJohnson I will be riding out from Bolton, so through Bury if you want to meet up on the way?
AJ & Trio - we'll meet you wait at the gates to Centre Vale Park at 10:00 then. That's on your left about 1/4 mile after the roundabout in Tod in the Burnley direction. It beats hanging about by a busy roundabout and we'll be going up the A646 towards Burnley anyway.
For you, Littleborough-Littleborough will be about 100 km (62 miles). You'll have to work out how much you are doing to and from Littleborough on top of that.
For those of us doing Hebden Bridge-Hebden Bridge it will be about 105 km (65 miles) but at least the last 14 km (8.5 miles) are down hill or flat.
Alun/Trio - I've just discovered that I haven't got your numbers. I'll PM you mine and if you send me yours I'll be able to contact you if there is a problem. If you ever want to contact me outside of CC rides though, PM or email is the way to go - I never carry the mobile any other time.
Alun said:
I'll be there! Weather forecast looks OK, let me know when and where to meet you. Market Place CP Hebden Bridge?
Excellent. Make it 09:30 Alun and then we can have a leisurely ride over to Tod in time for 10:00.
[Nasty bastard climb to TV tower...]
colly said:
Dear God !! Well that's me out then.
There are several other hills almost as bad as that one!
Calum - looks like you are out then unless you have a rush of blood to the head and decide to ride over from Halifax -
hint, hint. They only allow (fully folded) folding bikes on rail replacement buses. There is a train which would get you to Halifax in time to ride to HB. It's about 8 miles to HB from Halifax and largely downhill/flat on the way here. You could get to HB in just over 30 minutes so if you are going to do that let us know and we'll wait for you.
If you wanted to take a shortcut back Calum, we will be crossing the A646 at Luddenden Foot about 7 km (4 miles) from Halifax late in the ride, so you could leave us there. Alternatively, when we climb the A58 to Blackstone Edge, you could head ride down the A58 to Ripponden and have an easy ride down to Sowerby Bridge. From there it is only a couple of miles to Hailfax station - one shortish steep climb and then a downhill run into town.
colly said:
Have fun you lot. And if you have any....fit some low gears.
Yes - some combination of low gears, strong legs or SPD shoes for the walking bits will be required. I also recommend that you check your brake blocks - I almost wore out my rear blocks on the wet Wharfedale ride last weekend and will probably replace them before Sunday's ride. My slow puncture mutated into a fast one when I got home so that will need sorting out too.
