What tyre make is it? Also, if your punctures happen in the same area, go for a walk and study the area for glass, nails etc.....It could be that?
It's continental GP 4000s II. I know they're not crazy puncture proof but this seems remarkably quick. Not in the same place
Are the punctures always in the same place on the tube? Are your tyres thin and weedy? Are you running very low pressures?
Just some random questions, the answers to which may lead somewhere. Or perhaps not ...
So i've checked the two previous tubes (pre tyre replacement) and they were indeed in the same place, on top of the tube. So i'm guessing something must have been in the tyre. This one tough (with the new tyre and rim tape) isn't in the same place annoyingly. Pictures to follow on next post
What tyres are they? I see you are in London, where the streets are paved with broken glass! If it is a stock off the shelf bike they usually come with rubbish tyres so it may just be the type of tyre you have does'nt offer any/enough puncture protection.
Now you are home I'd check the tubes you have that have already punctured, pump some air in them and get them in the sink full of water. Are the punctures happening in the same pace on each tube? If so that hints there is still something embedded in the tyre, or the rim tape at that section is maybe chaffed and causing the flats, or maybe there is a dink/nick in the rims at that point that has a sharp bit that is causing the flats maybe.
I'd do that first, if they are not in the same place and all seems well you may just have been unlucky.
haha edit, beaten to it by those above
As above. The latest puncture is in a different place. Think maybe I'm unlucky? It's kind of on the side (pictures to follow). Think that it could by anything to do with the rim/tape/spokes?
Punctures happen. It might be months before your next one, it might be hours. There's no rhyme or reason to it.
Best way to avoid punctures is fit Schwalbe Marathon Plus tyres, but they might feel slower than your current tyres - that's the trade-off.
Unfortunately given i also race (badly), got to go with semi quick tyres so I accept this will happen occasionaly, just questioning it happening so much!
I had a Shimano wheel that was just bad. Every time I went out I was getting punctures. Replaced the rim tape with extra thick tape, went round the wheel inside and out numerous times and couldn't find any sharp bits. Checked the spokes. Used new tubes and tyres. Puncture after puncture. Almost all were on the inside (suggesting it was the spokes or something inside), often in the same position. Just couldn't figure it. Reverted to the original wheel(*) a few years ago - no punctures. Earlier this year I thought I'd give the Shimano wheel another go. Did all the above checks one more time and went out... four punctures in 30 miles. Let a few other people have a look to see if I was missing something. No-one could find anything. Binned the wheel and bought another. No punctures so far (I touched wood). Sometimes you just get an evil wheel, is the only explanation. Kind of like a budget version of Stephen King's Christine.
(*) I have a Tricross and had invested in a set Shimano wheels so I could have both a road tyre and a more off-road option
I'm starting to wonder if it is this :s I hope not, but I guess if it happens again in next couple of weeks, I should probably contact the wheel manufacturer!
It will be the replaxing of the tyre that's the problem, that replaxing is a black art
Maybe that's where I'm going wrong! haha.
Any obvious things I may be missing when putting a new tyre in?
I've got a Shimano wheel like that, I think it's due to the mahoosive holes that allow access to the spoke nipples but TBH by the time I've realised and stopped there are a bunch of 'snakebite' punctures in the tube so it's hard to tell which was the first one.
Only one whole on each of these tubes
Schwalbe Marathon Plus tyres are pretty effective if you're staying with clinchers, use their inner tubes as well. Be warned that they are frequently a wrestling match to get on and off and you will learn some new swear-words... if you're running carbon rims then get the Campagnolo tyre spoon rather than attacking them with metal levers, if you're using any normal rim then use metal levers... Brompton put a good set in their toolkit....
Pity they're not quick
I guess it does come down to if I put on a quicker tyre I can't moan, this just seemed much much too quick, especially after so many other punctures previously!
