Kestevan
Last of the Summer Winos
- Holmfirth.
Do you know the differences between the Touring & the 800 ?
I am able to build a .gpx file for our holiday route, perhaps 300 miles of many points: I just wondered if both of these can take that and "perform" as the navigation device well.
Indeed, I may plan the things as daily routes, so could be 4 or 5 of them.
I can see the Touring can come with "Garmin Cycle Map of Europe and Points of Interest" - is that better/same/worse than just downloading the OSM mapping ?
Maybe I ask too many questions!!!
thx
AFAIK the Touring is the same hardware as the 800 however it has different firmware. Main differences are the touring has no ANT+ support, so heart rate monitors, cadence sensors and power meters cant be used. It also lacks the "training" features of the 800, you don't get the ability to race against a previously recorded segment for instance.
However the Touring does have a route planner, and will navigate to a location using either on-road or off-road cycle tracks. It also has a trip creator.- specify the distance you want to ride, and it will suggest (and map) 3 circular routes of approx the entered distance, starting either at current location, or a specific start point.
You can also download pre-defined .gpx tracks to follow and it will map and way point then like the 800.
The maps that come with the unit appear very detailed, the zoom function allows a very clear birds-eye-view of the route, and also a 3D style layout like most driving satnavs. - cant answer the question on OSM mapping as not used it.
