Just out of interest and don't wish to hi-jack the op what is the concencous on torquing a cassette amongst the cyclechat members.
Must admit I never have.
So is it still the right tool I need even with the pin in the middle? Cheers!
Nor me, in fact i never use torque wrenches. I prefer to use feel in how much i tighten anything anything up, rather than have faith in whether a torque wrench is calibrated properly.
And make sure the lock ring is perfectly flat against the threads in the freehub when you start to torque it up, if it’s at all askew, you’ll never get it to torque up. Best practice is to use a Torque wrench, however, all you really need to do is tighten the lock ring until the cassette doesn’t have any play in it, then tighten it two more ‘notches’.30Nm is plenty. apply a smear of copper grease on threads. The likelihood is the cass is going to be on the hub a long time, so protect against corrosion weld
The cassette tool is like an inverse socket, that is a standard socket.Why don't people use one of these instead of a torque wrench?
https://www.ebay.co.uk/itm/S-T300W-...207620?hash=item1ca4a2a844:g:IU8AAOSw~epdCNm2
