for anally retentive ham fisted spanner mangler type people ??
they have their uses but its not the be all and end all
Replacing the cranks. Apparently they can be pretty finicky about how tight they are.
really ?Replacing the cranks. Apparently they can be pretty finicky about how tight they are.
really ?
But that's just me and with a non-mechanical background, others that are used to this sort of thing may never have made my sorts of errors.
if nothing ever fell off or came loose, then they were not errors....![]()
fortunately no harm was done but I felt terribleBit heartbreaking if you over tighten the stem into your carbon steerer tube and crack it, or perhaps worse - the seat tube from over tightening the clamp. You can all play billy willy waver, I do it by feel as much as you like - I'll remove any doubt and use an inexpensive tool to ensure I hit the torque I intend to, every time, no matter how many times I adjust things.
Comparatively cheap, as in a £2000 frame is worth getting a £50-100 torque wrench to use on it. If you look after your tools properly and release the tension when you aren't using it then it won't need constant recalibration and the only thing that will happen is actual torque will be less than advertised when it loses spring tension, which is still preferable to believing some mystical power will tell your brain when your hand reaches 12Nm. Suggesting its better to not bother is bizarre. Torque wrench > cheaper torque wrench >>> The Force.
Cracking advice to spread that is.
"Basically, if you crack something you've gone too far, and if something comes loose during your ride you didn't go far enough. It's the best way to learn, trust me! I'm an expert."
I suppose you're one I those guys who can tell exactly how fast 77mph by feel alone, or can cut a shelf to exactly 4'8" without measuring.
You know, the guys who get all the speeding tickets and have to buy more wood after cocking up the shel measurements.
