Mr Messy, you build cars and I am the PDR guy. I think we agree here on a few points.
One thing though nipped up tight at 25 maybe different from nipped up tight at 75.
with calibration cert ? otherwise how do you know its correct . just sayin............Thanks guys for all the (conflicting) advice
General consensus seems to be better safe than sorry & I have today taken delivery of the Giant torque wrench today
I've seen three BMW M20 engines (1980's stuff) that had head gasket seepage between cylinders 5 and 6.
The cause every time was some grease-monkey NOT using a torque wrench whilst re-attaching the gearbox
bellhousing (clutch change on two and auto-gearbox change on another).
Basically if the bellhousing bolts are overtorqued the stress pulls the engine block out of shape, and any head
gasket that has seen hundreds of hot/cold cycles isn't going to like this.
Torquing of which, i've also seen two BMW M20 engines that have chomped valve heads because .... the camshaft
pulley retaining bolt wasn't tightened to the correct torque.
Over time the bolt loosens slightly (hot/cold cycles again), causing the pulley to chatter to and fro on the retaining
dowel ... which causes a slot to wear, increasing the "sloppiness" eventually loosing that 0.8mm clearance between
piston and bank balance.
Its torque wrench AND threadlock onto CLEAN threads with me whenever working on engine/gearbox/final drive stuff.
B&Y, it is not just about being tight enough, but how tight..
I invite you to a competition, you torque 10 bolts by hand and I check each one with a torque wrench. We will put the results up on the forum for all to see.
lets hope the torque value is a wet one if using threadlock otherwise it isn't going to be right is it .
B&Y how do you adapt to the different materials being used on today's bikes. Do you adjust the amount of nip you use on say handle bars and seat posts or do you use the same on both.
But the pro mechanics use a torque wrench. I wonder why, built and raced my own bikes for 42 years.
I would suggest for most people a small investment in a torque wrench is a good idea.
