Albert, I think you need to stop and have a read of the link
@Pale Rider provided earlier.
hobbsontour
Are you sure as 3w 6v is only 0.5 amp and a 1 amp charger would take 22 hours to charge this power bank, it dosent mention any less amperage for charging
Cheers
22 hours is optimistic. That's assuming you're always above the generating speed, don't stop and doesn't take account of the loss of energy.
The fact is that my powerbanks never get filled up on the bike because I am only looking to replace the energy that I am using.
Another reason it will take so long is because the powerbank is so big. Mine are 5000 and 10,000 mAh.
Also can somone tell me how this would fit my bike
https://www.decathlon.co.uk/28-front-hybrid-dynamo-wheel-id_8133890.html
No mention of bolt on or quick release and what about the connection with the dynamo? do need specific kit?
We don't know what bike you have, other than that it is, in your own words, crap.
We don't know how much weight you will be carrying and if any of that will be on the front wheel.
One advantage of
Decathlon is that if you do have any problems you can bring it to a Decathlon shop to get it fixed. But.... I believe they're a bit like
Halfords - some mechanics know what they are doing, others not so much.
From the specs
Hollow steel axle (quick-release not supplied).
I'm not sure if the Shimano connector is included, but they have one
https://www.decathlon.co.uk/shimano-terminal-connector-id_8078831.html
This is what you will use to connect your charger (and or lights) to the dynamo.
Or just ask Decathlon!
OK this is getting more complicated insofar as, the connectors and kit need seems really expensive as they normally include small power packs with them and I do not want a powerpack as I will have a bigger one. So does anyone know where i can just buy the connector and wire that goes to USB connector
Cheers
Ideas are suggested in the article Pale Rider mentioned above. Most are available on Amazon or specific bike shops such as SJS.
If you plan on stopping or staying in places where you can charge the powerbank, then you really don't need a hubdynamo set up.
