- Glasgow
Woooooooohooooooooo shes back![]()
Soz, been really busy at work, carried on cycling though
Yeah but, a slime (or similar) filled inner tube does the same, at a fraction of the cost @Pale Rider incurred by going tubeless.
What am I not seeing?![]()
Ah, all right, then it's really only worth the expense on a lighter bike with skinnier tyres, say a road bike or a tourer with 25's/28's.Weight, comfort and still the risk of snakebites, plus slime rarely seems to work at high pressure.
Well, according to the posts above, there is a chance you could end up covered in Stan sealant insteadI guess that depends if you like being covered in slime or not.
nothing , just carry a can of pitstop to do the same job . You can replace the innertube at your leisure http://www.halfords.com/cycling/bik...epair/vittoria-pit-stop-tyre-repair-cartridgeYeah but, a slime (or similar) filled inner tube does the same, at a fraction of the cost @Pale Rider incurred by going tubeless.
What are the panel’s thoughts on WHY this is better?
If you DO puncture, how do you get out of the doodoo?
Given that the actual total weight saving is about 100g per wheel and the inertia saving is therefore about 300g per wheel: Is it really worth it?
I love Schwalbe Durano but is there a comparable 700x28/32 that is Tubeless compatible with my H SON Archetypes? (Which as said upthread MIGHT work)
I am asking because I’m very much on the fence on this subject having listened to MTBs and Audax riders who chose to do LEL with them. I find it fascinating and I like to add strings to my bow. I like knowing how to do things.
Put glitter in the sealant for sealing larger holes.
Can anyone advise how often you need to replace/top up the sealant in the tyre? How is it done and is it a quick and easy job?
Presumably, an occasional 'shake' of the wheels should produce a 'sloshing' sound if the wheel is held close to the ear in a quiet environment and this will confirm the sealant is ready for action if 'punctures' strike. No sloshing sound equals solidified/redundant sealant?
Thanks
