Jody
Stubborn git
We get it, you don't like tubeless.
Has he mentioned the virtues of Tannus tyres yet
Better resistance can be achieved by avoiding tyres with pitiful puncture protection also. Comparing some tubeless tyres with cheap stock tyres is apples and oranges. I don't think I ever got a puncture with my marathon plus road tyres, using bog standard tubes, and I certainly never had to worry about topping up with sealant.
Of course, I'm not arguing the case that they ride better, or have less rolling resistance etc, just that puncture resistance can be achieved even with tube setups, one does not need to immediately give up on tubes.
As a get you home it's perfectly ok, I've done it.The handling at 30 psi, on a 700c x 23 or 25 mm road tyre, is borderline Darwin. Side wall cuts tend to turn into tears, and then you’ve got a useless tyre, and probably a knackered rim too.
I've not had a puncture in a tubed tyre since 2011, so you'll need a slightly more compelling argument than that to get me to switch back to tubeless.After two years of using tubeless had my first puncture yesterday, that sealant couldn’t cope with. Used a worm to plug the hole, no problem.
Much easier and quicker than messing around with inner tubes!
Tubeless is worth having because it means you can buy this cleverly designed and nicely made Lezyne repair kit and CO2 pump.
https://www.bike24.com/p2344124.html
