Two-wheeled trolls...
winjim
His riding style is not assertive enough yet at the same time overly aggressive. He needs to learn to take primary, but also to give way when appropriate.
Absolutely looking for a reason to sound his horn. It's so blindingly obvious what was going to occur! So sick of seeing this pathetic dross posted on the Internet. Slow down, let the bus pass, lower your blood pressure.
Absolute tosser.
kiriyama
Living in the country with lots of narrow roads. .. I don't get what the problem is here. The bus was already coming down the road when the cyclist turned onto the road. There was plenty of room for the bus and cyclist to pass slowly without issue. the cyclist could see the bus coming, and they could see the gap. If the cyclist wasnt comfortable fitting through that gap they should have just pulled over until the bus passed. (as they would have had to do if they were in a car.)
Fed up of these cretins making us look bad!
winjim
kiriyama
Common sense should have prevailed....bus doesn't appear to slow down which would be automatic if a less vulnerable road user, say a car, had been there instead of a cyclist.
looks like the bus is going very slowly to me.
That ridiculous horn going off is the only thing likely to cause an accident here
If I was to carry a knife, just in case a gang attacked me, then had to act on such an attack and killed someone then it would be labelled as "premeditated" despite being attacked by a gang first.
The same goes for "Cyclists" who carry a cam and a bonkers horn, in my mind!
I use the quotes because they're a completely different breed to the rest of us. Complete nobbers to be honest!
