I've just replaced the "Rabbit Ears" 3 speed shifter on my 2015 Brompton with the Sturmy Archer indexed shifterHi guys,
I want to upgrade the old style shifters / brakes on a 6spd Brompton to the post 2017 integrated kind. Can this be done?
Depends. No issue on S- or P-bars. With the older style M-bars it is doable but as there is formally too little space you have more or less one single possible position for brake handles and shifters and still a little less space for the grips than before. So it depends from your bars to a degree. Be aware that with the six-speed you'll need the newer dogleg for the derailleur as well. It is not expensive but easily forgotten if you only look at the shifters and only regonized when you are in the process. Overall with new brake handles, new shifters, new cables an a new dogleg still a relatively expensive exercise.I want to upgrade the old style shifters / brakes on a 6spd Brompton to the post 2017 integrated kind. Can this be done?
This was not the question but as you seem to have a strong opinion: Why?I would not consider it an upgrade.
Not steveindenmark, but there have been reports of shifting problems in high ambient temperatures, apparently due to plastics expanding. There's a YouTube video where a guy takes the shifter apart and abrades some parts to increase the clearances.
This is the trouble with reports on the internet. Yes there have been a handful issues reported and there has been one person being *very* vocal about that (but possibly less competent regarding the problem and the Brompton in general). A bunch of shifters have been exchanged over the last 3,5 years since their invention.Not steveindenmark, but there have been reports of shifting problems in high ambient temperatures, apparently due to plastics expanding. There's a YouTube video where a guy takes the shifter apart and abrades some parts to increase the clearances.
I thought I was upgrading putting the new dogleg on my older Brompton, but after few months of struggle I kicked it off for good and life improved .
Can I ask what you put in its place, u_i ? I see some far-East sellers have a Ti spring for this -- do you think that would help?
https://www.sjscycles.co.uk/gear-shifters/3-speed-sturmey-archer-sls30t-thumbshifter-hsj962/
I did this also with one of my Bromptons and it is very much straight forward. Coming from the old style shifters you would need a new cable, coming from the newer post-2017 ones you could in theory reuse the existing one. However - the S/A Thumbshifter comes with a new inner cable as part of the package, so you can simply use that as it fits the shifter perfectly.Hi - Having made the mistake myself of having "upgraded" to the new Brompton shifters, I'm about to do what you've done and switch the 3-speed shifter to the Sturmy Archer thumbshifter. How did you find the conversion? Were you able to simply swap out the shifter and re-use the cable or do you need to replace it? Thanks!
