Are you sure you're not mixing your Tektros up?
The 520 have only been available for a year or so. Hewitts used to come with Tektro Oryx.
PH you are indeed right my mistake it was the Oryx, sorry about that.
johnb5271 said:PH you are indeed right my mistake it was the Oryx, sorry about that.
So are the 520 and 720s better than the Shimano BR550s as fitted to the current spec. Cheviot SE?
Percy said:I was carrying my Zefal using the pump peg on my Cheviot SE and, thanks to a large pothole somewhere in France, the pump bounced out and into the spokes, shredding the valve fitting end of the pump and rendering it near useless - I certainly couldn't put it back on the peg again (had to cable tie it in the end). The lesson here, obviously, is to avoid potholes, but worth bearing in mind!
After much deliberation have decided to get a Hewitt SE, after reading rave reviews (espc. about his hand-built wheels, and the thorough fitting service offered) as have a few tours planned this year...
Anyway, am getting fitted for it next weekend, combining with an overdue visit to an old friend in Lancaster. Am v.excited!
bike_the_planet said:G'day
I'd be interested to hear about your fit goes - Paul Hewitt has a reputation for a comprehensive fitting service. But if I understand things correctly, the frames of bikes such as his Cheviot only come in four sizes anyway - a sadly common problem with most of-the-peg bikes these days. This means that, unless your dimensions are such that your measurements fit nicely on to one frame, the fitting will be a compromise requiring an excessively short/long stem or a seat post requiring excessive set back.
The only off-the-peg 700c-wheeled tourer that seems to come in enough sizes to really fit most people is the Thorn Club Tour - I think they come in 10 sizes now.
When I last looked at the Cheviott specs, at 6'3", I wouldn't have fitted even the largest one without an excessively long stem.
asterix said:When I bought a zefal recently I gave Spa Cycles the frame details and they sent a size longer pump than I expected. It fitted very well and the shorter size may not have been firm enough on the peg.
Good luck.
GrahamG said:They offer a custom frame building service too - I ended up getting one after my fit showed up some unusual dimensions. That was for an audax bike though.
Oxford Guy - If you're thinking of a Schmidt, I'd suggest just mail ordering one to take up there and leave with Paul to build into the wheel for you to save paying for a front hub you're unlikely to use.
oxford_guy;581781][quote=GrahamG said:They offer a custom frame building service too - I ended up getting one after my fit showed up some unusual dimensions. That was for an audax bike though.
SJS have the 36 hole version of the SON 28 for £172.99
http://www.sjscycles.co.uk/product-Schmidt-Schmidt-28-Disc-Dynamo-Front-Hub-36-Hole--Silver-3988.htm
Before I order, is there anywhere else I could get this cheaper (e.g. from Europe)? Thanks
Not this but by all accounts just as good, I have the older version of this and it is an excellent piece of equipment. Plus you would still have a £100 spare to go towards your racks.http://www.roseversand.de/output/controller.aspx?cid=156&detail=10&detail2=9829
oxford_guy said:SJS have the 36 hole version of the SON 28 for £172.99
oxford_guy said:So are the 520 and 720s better than the Shimano BR550s as fitted to the current spec. Cheviot SE?
User482 said:I know that the standard Cheviot uses a cheaper tubeset - does anyone know how it rides in comparison to the SE?
