Vaseline ok for pedal threads?
brokenbetty
London
I'm just about to replace my pedals. Being a bike maintenance novice I don't have any grease in the house to grease the threads. Will Vaseline do the job?
T'voices on t'Interweb say no but that's usually in the context of using it instead of grease in bearings. This is just to stop the threads seizing - there shouldn't be any movement between the surfaces.
I promise to buy some grease next time I'm at a bike shop.
Liz
alecstilleyedye
nothing in moderation
better than nothing imo. try and get some grease (finish line's is excellent) and redo the threads some time soon.
Davidc
Somerset UK
I used to use it years ago for all sorts of jobs which needed grease. It worked OK but the specialised greases now available (try the LBS) are better.
Fab Foodie
Kirton, Devon.
brokenbetty said:
Thanks guys - I've vassed them for now but will grease them properly this week.
Really no need. Vaseline works fine, it's pretty much the only thing I've used for the past 30 years and all of my bikes and the families run fine. I tried all kinds of other greases and they offer no advantage that I can see.
I re-assemble all my bikes with Vaseline and use it on all the bearings, wheel, headset, freehub and in the old days bottom brackets etc. No worries, whack it in there and relax.
Useful when touring, one less thing to carry as has multiple uses!
I'm sure I remember being told that Vaseline can encourage moisture or something, so I have never used it, just decent grease. However, I seem to rememeber my Dad using it occasionally.
Fab Foodie
Kirton, Devon.
No water attraction. Really, it's a perfect bike grease!
From Wiki...
Petroleum jelly is a flammable, semi-solid mixture of hydrocarbons, having a melting-point usually ranging from a little below to a few degrees above 167°F (75°C). It is colorless, or of a pale yellow color (when not highly distilled), translucent, and devoid of taste and smell when pure. It does not oxidize on exposure to the air, and is not readily acted on by chemical reagents. It is insoluble in water. It is soluble in chloroform, benzene, carbon disulfide and oil of turpentine.
There is a common misconception (resulting from the similar feel they produce when applied to human skin) that petroleum jelly and glycerol (glycerine) are physically similar. While petroleum jelly is a non-polar hydrocarbon hydrophobic (water-repelling) and insoluble in water, glycerol (not a hydrocarbon but an alcohol) is the opposite: it is so strongly hydrophilic (water-attracting) that by continuous absorption of moisture from the air, it produces the feeling of wetness on the skin, similar to the greasiness produced by petroleum jelly. The feeling is similar, but petroleum jelly repels water, and glycerine attracts it.
tyred
Ireland
I use Vaseline too and have had no problems.
IMO, it is cheaper than proper bike grease and superior for bicycle applications than the sort of cheap greases available in the motorfactors for car use which dry out and then provide little lubrication. They are designed to grease the kingpins of your Austin Cambridge every 2,000 miles so never get time to dry out when used for their intended purpose.
