mudsticks
Obviously an Aubergine
Last Monday I went to my local retail nursery and purchased potting compost, grow bags (I use the peat in containers for tomatoes in my glasshouse), the veg transplants they had available as it's early and tried to buy seed. ALL the veg seed had been wiped out over the weekend so I had to go to B&Q. I don't have the varieties I usually grow but at least have all I need though I did forget spinach beet.
Lockdown the next day so I'm very glad to have had the foresight to do this.
A tip for tomato growers if using containers. Get a two litre plastic bottle, make 3 holes in the cap with something like a bradle, cut off the bottle bottom. Insert a 9/10cm pot in your compost and then place the bottle in cap downwards. Fill with water or feed as necessary. This will allow slow release of the water in to your compost and avoid wasted water draining straight through. It also allows one to regulate the amount of water or feed given to the plants - overwatering or erratic watering is the single biggest issue with growing tomatoes at an amateur level. The cap will block from time to time, remove the bottle and cap, was thoroughly and replace. Tomatoes need a regulated constant amount of water - not drought and flood.
I use two bottles per container as I have two plants in each. The containers are approximately 90cm in length
If I was a proper profiteer, I'd be selling off surplus spinach beet seed, at overinflated prices..
Try 'Moles' seeds, online they're pretty good.. And their gold seed packets make you feel special
