Vinyl records, original or remastered? Advice required
Grant Fondo
Cheshire
A pal of mine is a bit of a hi fi geek, albeit grounded in science and engineering, was telling of a hi fi show where someone was quite seriously selling little wooded blocks to lift your cables an inch off the floor, presumably to reduce interference from, umm, the carpet. Wtaf?
Better give that a go. Teak or Mahogany?
swee'pea99
"...ideally you should match your electrostatics with a dipole subwoofer as its sound distribution pattern or directivity is a better match than that of a standard omnidirectional sub. Its sound output off-axis falls to a null at right angles, so with correct placement you can minimise excitation of room resonances (or 'boom') which colour the sound in most conventional installations."
Goes without saying John.
Oxo
Cumbria
The blocks need to be treated with a matt varnish as a gloss finish with reflect the sound and bounce it round the round.
And of course all Capacitors should be replaced with wood-encased versions (drill hole in block of wood, take metal case off, pour beeswax around cap and leave to harden)
Grant Fondo
Cheshire
Make sure the grain is aligned with the signal in the cable
Also, is the lead shot in my speaker stands dense enough? The Dynaudios sounded better in the hi fi shop?
threebikesmcginty
Corn Fed Hick...
...on the slake
OK to summarise:
Get the best kit you can for your budget. Don't fall for hype and BS. Get the set up in the right place, moving existing speakers can be better than an upgrade!
With vinyl (and CD), do your research on the best version of an album release available - it's not always the latest. Check label, where pressed, remaster eng. Don't fall into the thicker vinyl is better trap.
Don't forget music is meant to be enjoyable, even jazz.
S
slowwww
Surrey
OK to summarise:
I was with you right the way up to your last comment. No amount of research or spend can make jazz sound enjoyable. Or Country and Western. And most Folk
Oxo
Cumbria
OK to summarise:
Think your last sentence is slightly off key. Jazz is enjoyable and some other music is ment to be.
