If I push the mastic gently, more holes open and water poles out then stops.If it is behind the render you would here it if you tapped it.
If the render is solid then there is no water behind it.If I push the mastic gently, more holes open and water poles out then stops.
Tapping the render does nothing
The frame has weep holes in they should show on the out side of the frame or they are underneath
Water builds up inside the frame so they water needs to come out its normal.
View: https://www.youtube.com/watch?v=KZvPXNfafTM
Will go check all around above window. Thank you for the tip Hope it’s all solidIf the render is solid then there is no water behind it.
Yep I see this on the rear door but the water is not in the frame it’s from holes in the mastic around edges and dripping out from top above window where it seals to render. Render is crumbly in places and when I pushed the mastic in one point it had a gap to render and water poured out. It’s the front room window and above the frame
Render solid, just mastic not sealed to render and holes all over. Water running from behindIf the render is solid then there is no water behind it.
I would need to see a picture of the above window.
Is there a sill (External) on the window above ?
The water could be collecting in the frame above a passing through.
Yes, a bedroom window directly above like belowIs there a window on the first floor above the down stairs window.
Yes timber frame building. Will check upstairs window. Thank you for help, appreciated itI would be inclined to be looking at the window above the water is passing through from above.
The K rend rendering looks fresh so it not passing through there
They look like a timber frame building.
