Waxing your chain tips?
super_davo
I'm planning on trying waxing when I replace my current chain. The latest waxing pot has a built-in agitator that is supposed to help get the wax into all the nooks and crannies so I have been wondering if my ultrasonic cleaner could do the same thing? Melting enough wax to cover the chain in the cleaner would be impractical (I think) but putting the chain and wax into a zip-tie plastic bag before heating might work ... maybe 🤷‍♀️
Has anyone tried this or have any thoughts on the matter?
If you mean buying a bespoke for chain waxing system like Cyclowax, yes it will work, and I am sure it would do a great job, but it will cost £££££.
One thing I've recently changed to is using a cheap wax heater (for hair removal) in place of a slow cooker. Mine cost less than £10 from AliExpress, but you can get similar on Amazon for not much more if that scares you. The advantage is you can set the wax temperature at anywhere between 65-75 or whatever is the perfect temperature to 'just melt' the wax. You can switch on with a chain on the top of the unmelted wax, and leave it for as long as you like. A few shakes of the pot to agitate after it has melted, then remove. Turns the whole thing into an 'unattended process'
If you've already got an ultrasonic cleaner, you've already made the biggest expense, and a single bag of wax lasts absolutely ages.
EckyH
It wasn't me!
An acquaintance puts his chains with some drip wax in a plastic bag and put the bag in the ultrasonic cleaner. He said that this method works really well.
Meanwhile I tested a very basic approach for new chains.
First step is to "degrease" the chain: Towing the chain through a degreaser soaked rag. Even a penetrating oil like WD40 will do. The goal is to reduce the original chain lube at least on the exposed parts of the chain.
After that just putting drip wax on the chain. The drip wax and the remaining chain lube will form some kind of emulsion until the water in the drip wax is dried. Then some of the chain lube is in the "solid" wax. After 200km or so it's time to "refresh" the wax: Towing the chain through a dry rag removes most of the wax and some of the chain lube which is still in the chain after the first step. Putting on new drip wax results in an emulsion with more wax than in the first iteration.
Over time the drip wax replaces the original chain lube.
In my experience it makes sense to shorten the first intervals between the "topping up" of the drip wax to prevent that dust and grime form a dark alliance with the original lube.
I don't use bike specific drip wax anymore, because I've found a source for industrial wax emulsion with 45% wax. Used that through the winter in particular on the commuter and it works well.
And yes, I think that the approach to degrease the chain completely and put it in melted wax, move it a bit in the wax and let it cool down is still the most effective method.
And no, chain waxing isn't the best choice in every situation.
E.
Bristolian
Bristol, UK
Yes, this is exactly what I'm thinking to try. It's reassuring that your friend says it works :okay:
I appreciate waxing isn't perfect for every situation but my riding normally involves a fair amount of country lanes which, even now, are still wet (with water draining off the fields) and covered in mud/crud/bovine excrement which is attracted to wet lube like moths to a flame. Wax should reduce that and also make daily cleaning of the chain quicker. Drip wax as a top up measure is a good idea :okay:
super_davo
A few things... firstly, you are making the initial waxing process much more complicated than it needs to be. If you have an ultrasonic cleaner already, then the best thing by far is to use that to clean the chain. 20% degreaser - I use Screwfix No Nonsense at about £10 for 5 litres, 80% water, run through twice. Whichever method of waxing you use from there, either drip or hot wax, it should stick.
If you want to use the ultrasonic cleaner as the heat source / bain marie to melt wax in a bag, it will work. I don't think you really need the ultrasonic blasts to agitate though; because the wax is so thick it is more important to articulate the chain which happens far more via swishing around in the melted wax. Wax in a bag for me is messy, unless it is a very thick bag like Silca ship theirs in or alternatively the sort of bag you can buy from the supermarket to store soup. IMO way easier to get a dedicated wax heater - I have something very similar to this https://www.aliexpress.com/item/1005006615669077.html. You can just set and forget, few swishes, done, as per my earlier post.
With regards to drip wax to top up - totally the way forward. I use Silca wax because it is supposed to work alongside their Super Secret drip wax. Albeit it seems to work just as well alongside Squirt, which is much cheaper, and comes in tiny little 10ml bottles which are ideal for travelling.
With regards to keeping cleaner, there is no question wax just leaves your drivetrain cleaner, dirt doesn't stick to the outside and get transported in etc. However, if you are riding in wet conditions all the time, it does not give you anywhere near as good protection against rust, both on the chain and on the cassette. For that reason, my winter bike is the one bike I have where I continue to use oil on the chain. You can minimise the likelihood of rust by being meticulous drying your chain - I use an air duster like this https://www.aliexpress.com/item/1005010529420944.html to give a quick blast after I've washed my bike, a wet ride etc. After a wet ride or wash, wipe with a cloth, a minute blast with the air duster - doesn't take particularly long and I have not had rust since I've been doing that.
EckyH
It wasn't me!
That.
A note on chains with bushings: In my experience drip wax must be applied not only on the rollers, but also on the gaps between the inner and outer plates. The bushings prevent that the drip wax on the roller can reach the space between the inner and the outer plate.
E.
Moodyman
I’m all for progress and innovation, but there are some things in cycling that one has to shake their head at.
PpPete
Chandler's Ford
Converted to waxing some years ago and wont go back to oil. The cleanliness and vastly increased chain longevity make it absolutely worthwhile.
One tip though....avoid using a "corrosion proof" chain like KMC's "EPT". I've had two of these (one 9 speed, one 11 speed) fail catastrophically and exhibit multiple other cracked links after only a short period of use. I can't see wax at even 95ºC doing anything like that, much more likely to be the aggresive degreasing regime prior to first waxing, possibly causing hydrogen embrittlement. Never had the same issue with other KMC Shimano or YBN chains
VinSumRox
Scottish Borders
My riding buddy changed to one of the branded hot wax systems (he got a cheap deal!).
He is using it on his road, gravel and MT bikes , which get a muddy hammering off road and has been impressed with it , he doesn't bother topping up the wax just relaxes them occasionally. He has found his mtb chains have lasted longer than with oil. The chains definitely don't attract the muck that piled ones do and the mud washes off them easily.
The outside of the chain plates can go a little rusty as the wax must rub off the outside quickly.
I am almost a convert but not sure I can be bothered taking the chains off to rewax them as I just wipe mine down and add a bit more chain lube.
EckyH
It wasn't me!
In my experience the hot waxing is a bit overrated.
Topping up drip wax in a timely manner is sufficient if it's done carefully. I'm not stingy with drip wax to make sure that it works it's way in all relevant places on the chain. My method is to drip wax generously on the rollers and slowly turn the cranks backwards until I can see drip wax between all inner and outer plates of the chain.
E.
TC99
Well after using a hot waxed chain for a month I can report that i am very happy with it.
Its so quiet and smooth. The cycle itself remains clean. My trousers remain clean. I don't ride much in the rain so waxing washing off is not an issue for me.
jetman777
Hot waxing my chains was a game changer for me in term of bike maintenance and Drivetrain longevity. No more buying degreasers to clean the greasy grimy chains that dirt sticks to and wears out sooner. I still have some "Silica Chain Secret" wax pellets in the bag I bought 2 years ago. cost $30. Keep xtra spar chain master links on hand for the more frequent chain removals. I reuse mine 3 to 4 times. Be sure to let your wax cool down to about 140F before you remove the chain from wax pot for best results. I use an inferred temp sensor gun because I use a small rice cooker that has 2 settings Cook and Warm. I unplug the rice cooker and wait about 5 minutes to cool down. My 2ea XTR drive trains on my 2 MTB's are 2 years old with minimal Chain stretch.
YMFB
I think can see or understand the benefits of hot waxing. It’s the disadvantages that concern me. I watched numerous YouTube videos including GCN tech & The Cycle Workshop.
I ride all year including short commutes and longer weekend rides. lots of rides in the wet.
The Cycle Workshop said some people use normal wet chain lubes in the winter. If that’s the case I can’t see a massive advantage as here in the UK it’s raining often.
What do you do ?
Liquid lubes all year
Hot waxing all year
A combination
