I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
The day I hoped would never come is here.
My much loved commuter bike is finished due to a fatigue crack developing in the aluminium frame. There have been many, many happy miles in the last 8yrs and the bike has exceeded expectations in terms of comfort, speed, reliability and enjoyment so will be a hard act to follow. In fact, when I was involved in a serious RTA earlier this year on the way home from work one night I was actually glad I was on my fancy 'best' carbon bike and not the hybrid because the hybrid is my favourite, most difficult to replace by a long way.
Anyway, I have no choice now and need something to join the stable in it's place, but as expected I am struggling.
There is nothing in the current GT range that fits the bill.
My preferred option, and something I have often considered over the years, is a Kaffenback Frameset from Planet X. Cheap & cheerful and should allow pretty much all the bits from the dead bike to be swapped straight on. Problem is they only seem to have small and medium while I will need a Large or XLarge. No word from them on lead time for the bigger sizes but I don't expect it will be anytime soon so as a plan A this idea is dead in the water from the start
The other option that is very high on the list is this beautiful deep green steel KONA. I lusted for it when replacing my crashed carbon GT earlier in the year but opted to get another Grade as it takes the 35mm knobblies I have for off-road use. I am happy that it is drop bars instead of flat. Although I like commuting on flat bars I am equally at home on drops, hence occasionally taking the Grade to commute on nice days when there was no need to carry stuff or for mudguards. I can live with the fact it is specified with 'only' 30mm tyres.
The main problems making me hesitate with this are as follows;
Main criteria are;
TIA, Skolly
- It is stupidly expensive for a utility/commuter bike. The money isn't an issue and if it puts a smile on my face the way the Traffic did then it would be money well spent regardless. The Kona is now available with 25% discounts but £1.4k is still a silly amount for a neglected commute hack even though financially the cycling to work fuel savings alone will repay the purchase and running costs at least double if I keep it as long as the Traffic.
- It is so similar to my carbon 'best bike' as to be the same bike to a layperson (and my wife), many of whom will simply say why not commute on the Grade? This is a valid point except for the reason I got the hybrid in the 1st place. Which ever bike I commute on needs panniers and guards and once these are fitted that bike is no longer the weekend toy it was before, leaving me short of a bike. Once burdened with rack and guards the Kona will no longer be a steel copy of the Grade.
- My wife will not understand the justification of spending £1.4k on 'another' bike
Main criteria are;
- Steel frame. This is the 3rd aluminium frame I have cracked in my cycling life (but the 1st one not covered by warranty).
- MUST take pannier rack and mudguards
- Disc brakes
- Rigid frame/forks, absolutely no suspension even remotely considered so just don't OK
- Minimum tyre clearance for 28mm but would prefer room for 32 or 35mm if possible
TIA, Skolly
