What Have You Fettled Today?
DCLane
This lunch-time I had a proper look at the 2016 LaPierre Audacio 300 I picked up almost a month ago. An initial look-over got me worried about the front brake area and I've had to conclude the brake caliper bolt is seized in despite a LOT of soaking for the past three weeks :cursing:
The bike's been cleaned up as it appears to have rarely been cleaned xx( along with the rare usage, as shown by the original bar tape and cables (it's only ever had brake pads and a rear gear cable from what I can observe). It's basically an example of what happens when you use a bike a bit over the winter, then don't deal with minor maintenance.
The chain and cassette are in the bin as the chain was stretched beyond 1.0 and both were rusty.
Other Tiagra 4700/4703 triple parts are off as a) the crankset's 175mm and b) it's not a groupset I use. They'll be moved on via eBay, with the exception of the brake calipers. I'm keeping the Fulcrum Racing Sport wheelset for now after I cleaned up the freehub.
The frameset's been dismantled with the lumpy original Tiagra bottom bracket also binned. Inside the frame was xx( so that's been cleaned. The headset was also lumpy but, after dismantling and cleaning, I'm hoping it'll be OK with fresh grease.
There is some paint loss around both brake calipers, the worst by a long way is around the front fork. I'm guessing the calipers were installed a bit tight and water has got in under paint chips and spread. That's been cleaned, checked, and will be painted. Then I'll put the bars / stem / seatpost and brake calipers back on.
However, my original concern was correct and it's too big for me as the frameset's a Large size and I'm too stretched out. Therefore it'll be listed on here once I've painted it at an intentionally low price (does £20 collected seem low enough?) with those parts included. Should it not shift on here it'll go onto eBay at a more appropriate price. Originally it looked like this and no, I don't have a photo of the correct side:
