Gravity Aided
- Land of Lincoln
I buy a great many used bicycles, over the course of time. Sizing information is not always readily available on the bicycle itself, and there are variances among frame styles.Why?
For us tall peopleIME Cannondale do tend to use a slightly longer top tube than others. Suits me perfectly though.
It would be helpful if there was a standardized system of listing dimensions. For example what does centre (of bottom bracket) to top mean? Sometimes it means to the point level with the top of the top-tube where it meets the seat-tube , often it means to the very top of the seat tube (seat clamp) - without specifying how much seat tube is above the top tube. The useful dimension is the virtual top tube length of course, as many frames have a sloping top tube, to a greater or lesser degree. Standover height is also important to know, as is bottom bracket height if you are trying to compare frames.
If that is the case - it would be extremely helpful if manufactures could give BOTH measurements, so that you could determine exactly the position of the top tube junction on a 'compact' frame.The definitions are already standard. 'Centre to top' or 'C-T' means centre of BB to top of seat tube. It always means 'top' of the seat tube. The other measurement is 'C-C' which is centre of BB to centre of TT.
You are very likely correct - to put it another way, my point was that the length (if any) of seat tube above the top tube is never specified.The definitions are already standard. 'Centre to top' or 'C-T' means centre of BB to top of seat tube. It always means 'top' of the seat tube. The other measurement is 'C-C' which is centre of BB to centre of TT.
I'd like to see them standardise shoe sizes first... my feet are 10.5" long, but my wide variety of footwear includes size 9, 10, 11. Logic suggests, they all should be 10.5 ... do cobblers use elastic tape measures?![]()
Do you mean seat tube or seat post? Centre to top means the centre of the BB to the top of the seat tube regardless of where that is in relation to the top tube. The seat post is, ime, never included in the frame measurements (apart from I suppose monocoque TT frames.)You are very likely correct - to put it another way, my point was that the length (if any) of seat tube above the top tube is never specified.
Exactly. Many modern frames have a length of seat tube extending above the top of the top tube. Some extension is necessary to accommodate the seat post clamp, unlike a 'traditional' lugged steel frame where the centre to top measurement (usually) was the same as the centre to top of top tube measurement. Perhaps Sheldon Brown puts it more clearly than me:Do you mean seat tube or seat post? Centre to top means the centre of the BB to the top of the seat tube regardless of where that is in relation to the top tube. The seat post is, ime, never included in the frame measurements (apart from I suppose monocoque TT frames.)
