Each to their own, but just out of interest have you tried either?
I don’t think they have ever ridden a bike.😱🤣🤣🤣🤣🤣
Faff is debatable (personally I prefer regularly waxing chains to periodically having to clean filthy, gritty, oily drivetrains and the mess they create in the interim).
I'd argue cost is tipped heavily in the favour of waxing as the supplies cost naff all (if you're not buying the heavily-marketed industry kool-aid) and the drivetrain components should last a lot longer. Plus there's no outlay on stuff like degreaser and the myriad drivetrain cleaning tools that never really work..
I suspect the reason it didn't improve chain life much is because you were only removing contamination from the outside rather than inside the links where the wear takes place. Once contaminated in this way I suspect it's very difficult to clean it all out; I've never had much luck waxing chains that have previously been used with oil.Indeed, ,,faff being debatable.
Former commuters used during winter season, I was.lucky enough to be able to store my bike in my workshops at work...so used to remove chain probably twice weekly, thoroughly blast off any crud with a HP airline, soak in oil, drip dry for a couple hours and refit.
Faff to some ? Easy for me and each part only took a few minutes, almost effortless.
Did it increase chain life ? Not significantly
Didnt mind doing it at all but once the facility to do that was hone...I just returned to wipe, oil, wipe .
Its something that can easily be overthought with hindsight. Its a chain, it has a life, you can extend it a bit but not much IME.
Perhaps, but that still doesn't really make sense unless you're simply chucking on a new chain without cleaning the rest of the drivetrain first.I think maybe he was talking about the time involved in rewaxing a chain vs just replacing it more often.
My experience with waxing is that the UK is the last place I'd use it, it just rains too much.
The thing is this is a fallacy. Yes, by definition it rains in the UK on between 159 and 165 days, 43 to 45%, of the year. The source for this data is the Met Office.I think maybe he was talking about the time involved in rewaxing a chain vs just replacing it more often.
And as for chain waxing, 100% spotless running gear and the biggest plus, the life of the chain increased ten fold
All the testing I've read suggests waxing gives a significant increase in chain life, however I've not run oiled chains long enough to make a direct comparison myself and I'm certainly not about to start now
Granted it's not great in the wet but on balance I'd still rather use it than oil... I am in one of the less rainy parts of the country though.
You'd be amazed how much black gunk comes out of..and keeps coming out of a chain.
Luckily we has a stainless steel topped.bench so the.mess was easy to deal with.
Personally I suspect that method while not foolproof would remove as much or.more as most other methods. But, as said, its easy to overthink it.
I d only get 1200 to 1600 miles to a chain with regular maintenence (10sp) anyway summer or winter so the difference was only perhaps 3 or 4 weeks cycling (I used to religiously monitor chain life...another thing with hindsight I think you can overthink).
1200-1600 miles per chain? How bad were the riding conditions?
I always found wear progressively worse / quicker as I went up the speed chain.
I used to love to be out the saddle, push push push uphill, always attacking the road (in my own humble way)
I always assumed (no reason to disbelieve) that riding hard will accelerate wear.
