I have 2 levers, a mini bike pump (but not sure up to how many PSi that one pumps to) and I have 2 inner tubes. I haven't been on my bike for nearly 2 weeks because the paranoia of it breaking and me being stranded gets to meEarlier this year, bike shops continued (rationale was to support essential workers) but many dealt with customers at their door, rather than letting them inside. There's often a waiting list for repairs, but why do you fear your bike will 'break'? And it would be reasonable for you to not even ask to use a pump: the aim is to reduce inter-personal contact. Visiting a bike shop to borrow a pump has to fall into the 'non-essential' category.
Track pump - get one in next 48 hours.
Tell me you are carrying a tube, 2/3 levers and a pump when you ride. That pump can be used even if it hasn't got a gauge. Just calibrate the once with a pump with a guage: I know that 120 pumps (the one I carry is not full length) will get me 80psi.
Where are you stopping for the next month: uni or home?
I have 2 levers, a mini bike pump (but not sure up to how many PSi that one pumps to) and I have 2 inner tubes. I haven't been on my bike for nearly 2 weeks because the paranoia of it breaking and me being stranded gets to meI think I can deal with a punctured tyre now- but not 100% sure, I'm scared of trying to do it and then not being able to.
you need a track pump so you can pump to the right amount for your weightI have 2 levers, a mini bike pump (but not sure up to how many PSi that one pumps to) and I have 2 inner tubes. I haven't been on my bike for nearly 2 weeks because the paranoia of it breaking and me being stranded gets to meI think I can deal with a punctured tyre now- but not 100% sure, I'm scared of trying to do it and then not being able to.
This ^^^. Please do not be paranoid about punctures or getting stranded. The risk is low but the hazard (consequence) nevertheless needs mitigating. Do so by becoming sufficiently competent, through videos and then practice. Not that much difference from your studies; but 'hands on'. I have a daughter who like you has just started at uni. She has taken her bike and before term started I 'forced' her to take a wheel off, remove the tyre, replace the inner tube and refit the tyre, pump up and refit the wheel (and readjust brake). You are carrying what you need (no need to repair: just replace tube). Pump the tyre up with your 'mini-pump': when you cannot depress your thumb into the tyre that's well hard (enough) to support your light weight. I have suggested appropriate pressures for your tyres in an earlier thread.Have a practice run at home. Deflate the tube, take the wheel off, then take the tyre and tube off and re-mount both. And invest in a track pump for home. The mini pump is to get enough air in to get you home.
Okay I'll try it today, if I mess it up, it's Wednesday tomorrow- still no lockdown so the bike shop will think Im a donkey but they'll fix it.This ^^^. Please do not be paranoid about punctures or getting stranded. The risk is low but the hazard (consequence) nevertheless needs mitigating. Do so by becoming sufficiently competent, through videos and then practice. Not that much difference from your studies; but 'hands on'. I have a daughter who like you has just started at uni. She has taken her bike and before term started I 'forced' her to take a wheel off, remove the tyre, replace the inner tube and refit the tyre, pump up and refit the wheel (and readjust brake). You are carrying what you need (no need to repair: just replace tube).
Competence breeds confidence.
