Wind Speed Warning?
Lavender Rose
Specialized Fan Girl
Ashford, Kent
Does anyone have a rule regarding wind speed when deciding when to cycle? I have been thinking this for a while but never thought of asking on here :wacko:
I find nowadays I am always checking the weather, mainly for temp and humidity (especially when running and doing canicross with the dog) however, due to cycling in nearly 30mph winds and regretting it - I instantly get nervous if I see the wind speed anything over 20mph.
Although I am medium weight I guess (around 13st I estimate....the scales and I don't talk:shy:!) and my Allez is around 9kg, I feel it especially around corners. I am not sure now whether it's just a stupid mental thing I have created or if I should just get on with it :cursing:
Your own experiences please? and be kind :wub:
For me depends on the direction, I do a one way 25 mile commute at the moment , ie in from the east one day, back to the east the other, train in-between. Today I saw speeds up to 40mph for the journey home and was disapointed to see they went down to 20mph after 15:00, could have given some Strava PB's a good beating. If it had been a 20mph or above headwind or crosswind I would have caught the train. ( NB I am fairly small, 11 stone ish).
It takes a lot to put me off my cycle commute.
If the wind is going to be against or with me then 55 mph is my cut off.
With a crosswind then I’ll think twice if the wind is above 45 mph.
I’m heavier than the OP at 15 stone.
I would point out that I commute on very quiet country roads in the main, but am always aware of possible problems in strong winds. For instance, if the wind is coming from the left and I know there is a gateway or gap in the hedge coming up, if I know a car is coming up behind me (I have a bar-end mirror) I’ll pull over and wait until they’ve passed me before I cycle past the gap just in case I get blown out into the road. It doesn’t do your average speed much good, but Strava isn’t worth dying for.
I did have a tree fall on me last winter in a storm though! That’s why you should always wear a helmet. :whistle:
Alan O
Liverpool
I start getting cautious when winds get into the 15-20mph range, and will almost certainly avoid anything stronger than that. And it's not just the wind speed and direction, but how gusty it is - crosswind gusts can be dangerous.
I'll add that I don't commute, so I don't have any pressure there.
Lavender Rose
Lavender Rose
Ashford, Kent
I start getting cautious when winds get into the15-20mph range, and will almost certainly avoid anything stronger than that. And it's not just the wind speed and direction, but how gusty it is - crosswind gusts can be dangerous.
Exactly! It's the crosswinds as I swoop round a corner that scare me! I think today I will go running and cycle tomorrow as the wind speed apparently is no higher than 17mph :bicycle:
iandg
I draw the line at gusts above 40mph when I head out on the road. Head wind/tail wind not so bad, it's the sudden side winds that can take you across the road that are the issue.
I'm just under 13 stone
Drago
Its the gustiness that worries me. Wind isnt too bad today, but still some unoredictable strong gusts (and not just in my Y fronts) so my ride postponed, and don't want to end up under a lorry.
Lavender Rose
Lavender Rose
Ashford, Kent
I agree, better to be safe than sorry - especially as people's driving gets worse as the weather gets worse! At least I will get a run in today :wub::hyper:
glasgowcyclist
Charming but somewhat feckless
Scotland
I generally call off if the winds are consistently above 50-55mph.
With Storm Ali on Wednesday I was expecting to take the car but locally the wind wasn't too bad so I rode in. It was probably a 20mph tailwind most of the way for me but felt like a 40mph headwind on the way home. There were no real heavy gusts to speak of so I guess I was just lucky with my timing on both trips as there were some ferocious winds outwith those times.
nickyboy
Norven Mankey
I cycle for enjoyment and the enjoyment ceases above about 20mph
Problem is that's the official forecast speed. Get above 1000ft up and it's a lot stronger. Climbing into a 40mph headwind is not my idea of enjoyment
ianrauk
Tattooed Beat Messiah
Rides Ti2
For my commute, strong winds have never stopped me riding, however for leisure rides when it's blowing a gale, it's not nice and not worth the effort and pain.
