ayceejay
- Rural Quebec
This is where I politely bow out of this thread
This is what I would do/did do when my kids had their single speed 1st bikes and also when I was a lad starting out, back in the day, when we was too poor to have them fancy geared thingy-ma-jigsChain tugs are a bit of a faff. You don't really need them. Just get the chain tight by pushing the wheel back on the drive side. Nip up the nut, then square the wheel in the frame between the two chainsaws. Then nip up the non drive side. If tension is out then undo drive side and adjust.
You 'walk' the wheel into place.Then tighten up tight.
It has them, I assume they fit. Not sure what time I'll be able to get there to get the chain checked. Hopefully I can ride the mile as I've got a sore foot which hurts walkingPS Most chain tugs don't fit the Pearson frame. I have a Wills Wheels Version, same frame, but in a FASTER red colour. The tugs I ordered wouldn't fit the dropouts.![]()
Go on then, how did they show you?SortedAnd shown how best to do too...hopefully however I won't need to remove the wheel for a very long time with brand new Pro4 endurance tyres fitted
To hold the bolt with one hand, and stedy the tyre with the other while pulling towards and then how to tighten and straighten the wheel...he made it look easy...if it is only time will tell!Go on then, how did they show you?
Sounds dangerous!Chain tugs are a bit of a faff. You don't really need them. Just get the chain tight by pushing the wheel back on the drive side. Nip up the nut, then square the wheel in the frame between the two chainsaws.
In my experience this is about right ^^^^^Chain tension should be around 1/2" (12mm) of play in the longest section. If it is too slack it will fall off, too tight and you'll ruin the chainring and rear gear
