That's more of a would-burner thoughI live in a village (a local one for local people) and most of the neighbouring cottages have their fires going. Have a fireplace myself, just never lit it up.
Did the dog recommend them?All wood burning stoves are not equal. The cleaner burning ones are on an approved list and are considerably more expensive than an ordinary stove. I've also given up burning logs now and use the compressed logs, which burn better for longer.
He didn't mention it, it's a saw subject with him as he's not allowed in that room.Did the dog recommend them?
Does that have the same kind of provenance as your photo competition entries, Dan?![]()
Ahhhhhhh.
That'll do!The depths of the sewer that is my mind?
We did this when we had the roof redone. Amazing old split-lath battens which made brilliant kindling.I'm currently, and rather ironically, burning my house to heat my house. Having just had a loft conversion, the builders helpfully chopped up all the timbers for me to use.
Read the instructions re what should be open in terms of vents.Ok burner men have left and we are desperately trying to get it lit so any tips will be gratefully received.
Agree with this, though it varies with the make of the stove. My Clearview Pioneer has a wheel on the front which provides the main draught, then once that's shut the smaller adjustments are made with a slider underneath via a sticky-out handle at the front. My Woodwarm has main vents at the bottom of the front and the adjuster on the side near the top.Once the fire is well alight and the fire itself has warmed up you can close the bottom vents. The top vents are used to regulate the temperature and burn rate. Wide open the fire burns hotter but not as long. Closing the top vents a bit makes the fire burn longer, but the temp goes down a bit. Its very trial and error at first. Good luck.
