If I start and make a cock up of it, can I unwind it and start again, or is it stuffed?
Only reason I ask is that the bar tape I have bought is a bit pricey, and I'm currently leaning towards paying my LBS to fit it.
It's not a bad job to do if you take your time. Make sure the bars are prepared and the hood pieces are in place. And leave about a half inch overhang at the bar ends to be tucked in with the stopper things. I usually work from inside out. And keep the hood rubbers pulled back until your finished. Then some insulation tape at the stem end to secure the tape. Also, gel pads at the beginning if you've got them.
Yes, you can try and try again so by the time you are finished you will be an expert! By the way I did one recently and used tape from Decathlon for £6 and it was the best I have used, very comfortable too.
I've got a new set of mechs, cables and shifters to fit at the same time, so I might wait until the spring to let the existing ones take the brunt of the winter weather.
The youtube video that @Cycleops shows is the one I used and it is excellent. I got it right first time on one side but took two goes on the other. One tip is to leave enough overhanging the bars at the end where the caps are so that you can tuck inside. Good luck.
