G3CWI
- Macclesfield
Just received a range extender for my Orbea - ready for some longer runs in the summer. It's an odd beast. It does not look like a water bottle and is a bit clunky to use. It's not simply another battery but rather it works as a charger for the main battery. That sounds less efficient to me. It also seems to go against ebikemotion's own advice in that it charges the internal battery to 100% and I assume that it will run itself down to zero (safety low-voltage cut out I hope).
My bike has a small frame and that means that with the range extender installed, my normal bottle does not fit in properly as it hits the range extender. It has a rubber strap but the cage is poorly designed for the strap to attach. Apart from that it seems to work. Did I mention how incredibly expensive it is? Score 5/10.
