I have been trying to get the front mech on the Barracuda MTB to shift properly. It is perfect in the high and low settings but the middle ring just wont line up and the chain rubs on the inside plate of the mech. I did fit a semi-sealed bottom bracket just to get everything working and make sure the bike was actually worth doing up a bit before spending any money. The semi-sealed BB is 124.5mm, but the old one I took out was 122mm. Would the extra 2.5mm be sufficient to prevent correct adjustment. I guess given what is happening I may have answered my own question.
I usually start with no cable connected. Set up the high/low stops, connect the cable, take out the slack and Bob's your whatsit. Done it many times on many bikes without issue.
