In a similar bodge the flush mech broke on my pan some moons ago, my bodge, drill a hole in the cistern lid poke a wire coathanger through and hook around the trigger, make a handle of it on the top....voila, several more years of successful flushing. Now if I wasn't single that would have been a few weeks at most.
That is a professional bodge.Circa 2 years ago on a Saturday afternoon, a conveyor motor went all noisy, hot and vibrating a lot on me. No spare....
Strip motor from gearbox, test, now I know it's the motor.
Strip motor, bearing at the fan end is sloppy in the casting, casting is worn out.
Hmmmm...araldite, new bearing and some shim brass, centred it all up as best as possible and hope it's true or it will vibrate like the clappers when I start it up.
An hour later its rebuilt, turned it on....nice and quiet. Yessss.
'No guarantee offered or given, it might last a day, a week or all year' I warned them.
2 years later, it's still running.![]()
The day I moved into my previous house I hung some curtains in the hall window that were too long, so I cut the bottom off roughly and turned up a quick hem with staples. Those curtains stayed like that for almost ten years.
Circa 1979 I had a clapped out mini van. Brake lights suddenly failed....I'm not spending money on it, it's getting close to the scrap yard I suspect. The switch was on top of and part of the braking system, a valve IIRC. Disconnected the wires, spliced them so they were longer and reached the passenger seat and told my wife...brake...and she'd touch the two wires...brake lights come on.
Amazing what you're driven to doing when you are young, skint and need to do what you need to do. Couldn't envisage a bodge like that now..probably damage a modern car doing it.
Wasn't that standard on those doors.My mini van (reg numbers MBT 235F) had bits of dangling string to open the doors
Shaun
. It had been used by the BCF who had roundly trashed it !My mini van (reg numbers MBT 235F) had bits of dangling string to open the doors
Shaun
I knew before opening the thread it would involve toilet cisterns. Modern flush mechanisms seem to be ill-thought-out, flimsy, pieces of parp that demand bodgery when they fail.
Our loo flushes only courtesy of two zip ties.
I had one of those with the wires for door handles and an ignition button thingy on the floor.![]()
