Problem with legs is that it's extremely difficult to do this at home - quads are big and you would need a lot of plates; a proper squat rack is expensive and without it you would need spotters. On top of that, starting to lift will hurt your cycling performance as you will be extremally sore at the beginning.
That was me yesterday I increased my max front squat lift, failed on lift 2, catch bars caught the weight. Ive recently started again with weights so are quite a bit down in my best. I no longer do behind the neck squats. Im not interested in bragging numbers. I find im far safer-no need for a lifting belt with front squats. Once I get to around body weight 4-6reps, that's is enough-for my age its fairly decent strength
