The ranking seems reasonably fair and accurate. We are all roughly the same, but have different attributes, climbers versus flat riders, others can do it all very well.
Eg Lee can certainly give Paul a run for his money on a varied course
-and i tend to agree. Those of us who have raced less might benefit initially from the 95% of 20m but after that things should even up and most of us will be pretty close together. I do find it odd that I’ve done two races. Come middle of the pack in both really, and am ranked higher than you Andy. Haven’t you come near the top in multiple races? I thought you may of even won one. I also assumed that you would have a higher w/kg than me.
It’s no big deal at all. I just like to know how things work I guess. So I’ll have a read up on it later. That and I’m used to ranking systems that are based solely on results over a given time period on a point system like snooker, golf or tennis etc.
Seems reasonable. It puts me at ~1700, right in the C group which is where I race.https://www.zwiftpower.com/rankings.php
Zwiftpower has upgraded their ELO based ranking system and in near future KISS races intend to use these for Cats instead of the current w/kg system.
There is a basic FAQ on their page which gives an understanding of how things work. Cat A 2500+, B 2000+, C 1500+, D 1000+. From what I understand your initial Cat placement is determined by your best 95% of 20min in a race. You stay in that Cat until either upgraded or downgraded. However, there is an overlap of Cat boundaries. For example suppose you did 4w/kg (95% Cat) in at least one race, then you are automatically assigned Cat A. You stay in Cat A unless you lose 500 pts, i.e drop below 2000 points. Similarly suppose you are Cat B; you stay in there unless downgraded by losing 500 points taking you below 1500 or you gain 1000 points to get an upgrade which requires a ranking of 3000. So those in Cat B could stretch from a ranking of 1500-3000 if I've read it correctly. It's still in Beta at the moment so will no doubt be fine-tuned before implementation.
Personally, I like this a lot. Glory hunter sand baggers will naturally find their rightful Cat over time. Everyone will gravitate towards their proper level assuming they stay active. Not a perfect system but one that should lead to fairer racing.
What do you guys think? Are you in the correct starting Cat?
Crashed and burned tonight, lungs felt really tight. The pace was hard but not unbearable. Dropped out after 5 miles.![]()
I've been re categorised a C with a score of 1601
Bob........ C 1645
Paul....... A 2286
Tommy. B 2023
Lee......... B 2034
Dave...... A 2758
Carl........ B 1892
Jeff..........C 1771
Dean..... C 1564
Martin.. C 1710
I am not surprised I have dropped down. Time to do some lumpy races.
If you have not done so, click on your Profile tab. I think that is looking pretty sexy right now with the information displayed.As Dave alluded to, it's a work in progress. I will need a period of time to collate the figures to give a true reflection. I know I'm fitter, faster than last September. A recent drop in power stats is in comparison just before Xmas where I was in a purple patch of form. I just need a few races where I'm in the running at the finish to bump up those numbers.
