velocidad
- Between Hessle and Hull
yep my drive can be parked upon if that helps.
cheers, velocidad.
cheers, velocidad.
Hopefully the weather will stay dry & fine & the fields shouldn't be too much of a problem. I'll take the map with me & if anyone prefers a 'road' alternative we can sort it on the daymarinyork said:Other than that silly field between Dunnington and Stamford Bridge and the poor bit below Escrick I think that's a good route.
marinyork said:Thanks. I've not decided whether I'll do a loop or peel off at Selby and head for Sheffield, both are over 100 miles . We'll not get lost, several people on the ride will know the alternatives. If you wanted to head into York, rather than skirting it and meeting at the Knavesmire then alternatives would make a bit more sense, depends where you want your cafe stops.
marinyork said:Colly, is it going to be your 100 miler for April?
zacklaws said:Beverley minster at 1000am is fine for me. Looking at the route, some parts I do not know ie South of York and the North bank of the Humber for example so I presume they are cycleways etc and if so can you get by with a road bike or is it a mountain bike which is the preferable choice
craigwend said:Solty what weather have you ordered?
colly said:I seem to recall a cafe at the side of the cycle track when I rode on it last.
Not too sure about that may have been elsewhere.
