11 speed cassette barely fits on hub
benb
Evidence based cyclist
Epsom
So I ordered these back in January, and I do remember at the time that the cassette lock ring only just got enough purchase on the thread. However they have done 2,500km without any obvious problems.
I took the bike in to the shop on Saturday for a broken spoke, and when I picked it up yesterday they said they thought the hub might only be for 10 speed, and they were unable to torque it up to the recommended tightness due to lack of purchase on the thread. I took it off again when I got home, and the smallest cog definitely sits quite proud of the hub body.
I've checked the obvious, like spacers, and the individual sprockets being snug against their neighbours.
How do I confirm whether the wheels I have on the bike are definitely 11 speed?
Nibor
Bewildered
Accrington
What wheels / hubs are they someone here may just know.
simon.r
Person
Nottingham
Are you absolutely certain that the spacer to convert 11 speed to 10 speed hasn't been left on? Wheels often come with this spacer supplied.
Roadrider48
Voice of the people
Londonistan
I think you probably answered it for yourself when you said the lockring only just got enough purchase to bite.
And what with the LBS telling you they reckon it's a 10sp hub.
The lockring should really fit comfortably on and tighten up after you put the cogs on.
benb
benb
Epsom
They are supposed to be ProLite Revo A21: http://www.wiggle.co.uk/pro-lite-revo-a21-alloy-road-disc-brake-wheelset
That is what I ordered. I'll have a look and see if the model is printed on the wheel anywhere.
Pretty sure, but I'll double triple check later on.
U
User6179
The difference between 10 and 11 speed freehub is about 2mm , one of the ways to tell if you have a 10 speed freehub is the gap between the lockring and frame , it will just about be touching with a 11 speed cassette .
Roadrider48
Voice of the people
Londonistan
Hey Eddy,
How's it hanging mate?
benb
benb
Epsom
Definitely no spacer.
Distance looks like 35mm which corresponds to the 10 speed dimensions above.
The cassette looks spaced together ok.
But the smallest sprocket is definitely proud of the hub.
Also, some of the splines on the sprockets look worn. It's only done 2,500km.
So maybe wiggle supplied the wrong wheelset.
The only id I can see on the wheel is a barcode A516809 and a sticker saying Pro lite certified hand built PL-05138154
Any thoughts before I send it back to wiggle? I've put the original rear wheel back on for now.
