A lovely bit of cycling
rowan 46
birmingham
A cyclist was cycling down the A 41 in brum today the secondary position was spot on moved into primary for the upcoming junction smoothly and assertively stayed in primary for the upcoming lane filter and then dropped back into secondary at exactly the right time. It would have been perfect except for one thing not once did they check over their shoulder to see what was behind them. two cars put the brakes on. no harm done as there was plenty of room but a couple of mph faster or a couple of drivers who were not paying attention and that could have been 1 more tragic statistic. As it happened there was was plenty of room for the cyclist to make the manoeuvre but a quick check and a hand signal would have let the drivers know what was happening.
BSRU
A Human Being
Swindon
Unfortunately it's all to common to see some cyclists ride along without paying a blind bit of attention to what's going on behind them.
Tynan
e4
hearing does work in the right circumstances and you can see a lot from the corner of your eye
I find it hard to believe someone would move from secondary to primary on a main road without knowing it was safe to do so, a signal would be nice mind
4F
Suffolk.
Nah, he was perfectly safe. Whatever are you complaining about? He was using his hearing instead. ;)
He must have been listening to his I pod and so caught up with the music was unaware of what he was doing :girl:
Mad at urage
I find it hard to believe the OP could actually tell whether the observed cyclist checked behind. Hearing does play a strong and important part for those practiced in its use (I suspect many who don't understand this have poor hearing or are just not well practiced at distinguishing road sounds and their source); in addition to which (as has been said) you can gather a lot of information our of the corner of your eye with minimal head movement, to which I'd add: Use of a mirror and looking under the arm are both usually undetected.
Signal? To move some 18 or so inches across whilst remaining within your lane? I wouldn't even consider it in a car and very rarely see a need to use it on a bike. In fact I'll often deliberately wobble to discourage close passes.
Edit: Just reread the OP: "not once did they check over their shoulder to see what was behind them" - well precisely, checking over your shoulder is not the only way of checking behind!
BentMikey
Rider of Seolferwulf
South London
With your keen hearing, I think you missed in the OP that two cars behind him had to put the brakes on as a result of his unexpected manoeuvre. I'm quite sceptical of the sort of cycling that doesn't involve lifesavers and indicating to change lane position when there's traffic close behind. ;)
Angelfishsolo
A Velocipedian
That said I see so many car drivers who use their brakes far to often, on downhill especially. On one occasion I was engine braking for around 2 minutes whilst the car in front had its brake lights on the entire time. They must have been at the point of complete failure due to friction build up.
