BalkanExpress
- Brussels
Bought a bike fitted with Campag deltas: what is this thing you call “stopping “
For some reason all Campag calipers seem to have special powers, both my Campag equipped bikes seem to stop on a sixpence
I doubt that was QR failure, more user error. QRs are more than capable of putting sufficient clamping force laterally to keep the wheel in place, if you don't put the wheel in properly, there is no QR which could fix that.It's what other cyclists do so they can admire their beauty.
Regarding quick release and discs, maybe not such an issue with road bikes but there were stories of hard braking on mountain bikes (where of course discs are entirely appropriate) pushing the front wheel out. I don't think you can buy an mtb fork with QR nowadays.
Another advantage of direct mounts must that you don't knock the brake out of line when removing and replacing a wheel.Slightly better than regular calipers - the arms pivot about fixed points rather than floating which means they feel as though they bite quicker and you have slightly more control over how much of your lever pull translates into braking activity. They're much closer to disc brakes in how they perform than my experience with centre mounted dual pivots, although this is on good quality alloy rims I wouldn't want to comment on carbon rim braking performance.
Generally I'm quite pleased and don't feel I'm losing much vs my hydraulic disc braked bike except in the wettest conditions. Both bikes run full Shimano R7000 groupsets for reference.
Nope, that's true, hadn't thought of that, but you could argue that's a failure of centre mounted calipers rather than an advantage of direct mount. Users of cantilevers rarely complain of such issues.Another advantage of direct mounts must that you don't knock the brake out of line when removing and replacing a wheel.
