Thanks for engaging on this thread. For the sake of transparency I reported your first posts.
I do hope that since you are using this site in a commercial way that you have paid the (ironic in this case) advertising removal
subscription
Thanks for clarifying. Slippage is a non-issue as explained by our
user reviews. We've been proven in a multitude of off-road settings.
Some questions:
How long is the product in existence?
How many of those reviews paid for the product?
Our new tech isn't just electronics and wouldn't offer many advantages to a hub. ......
PedalCell is a bottom-up design for USB charging in every part of the system (deep integration between our electronics, software, and custom generator) which is why we have higher power output and better drag efficiency.
Frankly, the thought of a device like yours strapped to my front fork scares the bejaysus out of me.
It also seems that a key component in your offering is some smart communications technology.
If you could marry that with a hub I would be interested.
Also FYI our clamp doesn't slip when installed properly onroad offroad etc. All reviews back this claim up. And IF someone didn't follow our directions and it did slip, the Generator puck hits the spokes first and will rotate around them. We tested this fail-safe. We have yet to have anyone crash because of a clamp failure.
I'm starting to be turned off here.
Your claim is highly dependent on the quantity of units out there, the length of time out there and if the reviewer has received a free one.
Ever had a dog snapping at your ankles on a bike? My foot would go exactly to where your product would be on my fork to give him a good kick.
Someone who wanted to slow me down or stop me outright could do so with a well timed kick.
And a dynamo hub failure can absolutely be catastrophic if the bearings fail (which does happen and will seize your wheel).
That's just over the top.
Bearing failure has nothing to do with electrical generation.
Perhaps long term use of a dynamo such as yours reduces rim strength leading to catastrophic failure?
Again, see the above answer. All hubs are inherently limited in their charging spec due to their German-regulated power output. That will likely never change as long as the laws exist. If you want faster USB charging PedalCell's proprietary system is the only way to go at the moment!
I wouldn't bet on that!
Most of our riders increase their device usage with more tracking, GPS, taking photos, etc. when having access to PedalCell.
On a lighter note that's another reason for me not to want one!
For me, efficiency is only one aspect.
Simplicity of use is another.
Discretion is important. I've a Son hub and a Cycle2Charge unit. Someone might recognise the hub but the chargepoint is mistaken for a bell - on or off the bike.
Lifespan is another. The expensive part of my system (hub) is guaranteed for five years and can be serviced after that. (They honoured their guarantee when I was dumb enough to ride into a drain in Mexico - even in the midst of a pandemic).
Theoretically, it's a lifetime product.
I said earlier I view it as an investment - not a cost.
My charging unit is cheap and simple. I carry a spare cable for it. Something better on the market and I can upgrade just that.
What is the expected life span of your product?
In the meantime, PedalCell 2 should be based on a hub in my opinion.
