tdr1nka
Taking the biscuit
- SE London, Bandit Country
I think a shout of 'Other cyclists hate you!' shames them enough.
tdr1nka said:Going on the assumption that you were the following cyclist, would you expect a cyclist to possibly put them selves at risk to get you out of danger?
tdr1nka said:Surely it's your responsibility to not put yourself in danger if following another cyclist?
Jaded said:Frankly, if you can't see ahead that your route to the ASL is blocked and you then put yourself in a position where you could get left-hooked (or you think that getting to an ASL is the nirvana of cycling) then you need to think about your own cycling, rather than the person that has stopped.
Twiggy said:I don't expect others to keep me safe, but I also don't expect them to put me in a situation where I can't get safe easily.
and I'd certainly get upset if I got a snarky/rude response to a polite request to allow me to get to a safer position.
Twiggy said:not all feeder lanes are on the left of traffic.
and no, probably not a great example of another rider putting you in peril.
Cycling assertively keeps you safe, being forced into a passive position makes you more likely to be hit and killed.
Twiggy said:regarding statistics, go look for yourself, I'm not here to prove anything, just to balance the discussion.
Ok, lets re-read the encounter, from another perspective
"I was cycling down the street, and the lights changed to red, and I started filtering forwards to the advanced stop line, the lights have a long sequence so I've got plenty of time to get forward, I'm passing this bus when a GOB in front of me stops in the middle of the filter lane, level with the front of the bus.
I shout 'move over please' and get a 'the lights are red, I'm not going to kill myself by jumping them you idiot'
I admit, I get rather pissed off at this guy, he's not only blocking the filter lane, but is positioned so no one can get past at all, and I swear at him, before going back and setting myself up behind the bus.
Then to make matters worse he calls me an peanut as I pass him, what is wrong with these people, if he'd just moved a little to either the left or right I could have safely merged with the cue or got myself into the advanced stopping area, but no, he sat right in the middle, blocking off the entire way past!"
How'd that look for a situation where another cyclist is putting you in bad position by stopping at the worst possible place.
*but then, you're going to say, "you shouldn't have undertook the bus if the way through wasn't entirely clear" or something along those lines I'm sure*
