betty swollocks
large member
Haven't tried it.Do you still need to use sealant when installing the tyres?
Don't see the point of not using sealant.
Yes
Yes
No. You can install some tubeless tyres without sealant. UST standard was designed to allow tubeless tyres to be inflated with a track pump without sealant. Tyres which are not UST compliant may need sealant to keep them airtight. Some tyres are designed to need sealant. I had a Schwalbe one which was seeping sealant from new and the distributor advised me to paint the inside with sealant and reinstall.
A major benefit of tubeless is punctures mostly seal up and let you keep riding. Why would you not want to use sealant?
Thinking seriously about buying some Mavic wheels with tubeless tyres for my road bike. My main concern is that I read some less than flattering comments in the past about Mavic tyres. Are you happy with yours now you have had them for a while?Mavic now do a range of tubeless - wheels and tyres made for each other. Takes the faff away, as the tyres can be easily seated with just a track pump: first time (and in my experience), every time.
I've taken them on and off several times, just to be sure.
Wheels came with Yksion Pro tyres. They feel plush, grippy and fast, once you get the pressures (for your weight) dialled in. Wear well too. Two punctures over the winter, I'm aware off, which were both fixed by Stan's Race sealant, with minimal loss of pressure.Thinking seriously about buying some Mavic wheels with tubeless tyres for my road bike. My main concern is that I read some less than flattering comments in the past about Mavic tyres. Are you happy with yours now you have had them for a while?
What pressures are you using? I weigh 70 kilos and planning on 28mm tyres.Wheels came with Yksion Pro tyres. They feel plush, grippy and fast, once you get the pressures (for your weight) dialled in. Wear well too. Two punctures over the winter, I'm aware off, which were both fixed by Stan's Race sealant, with minimal loss of pressure.
Schwalbe One pro 28mm on c zero rims 96kg 73psi front 83psi rear. Still experimenting.What pressures are you using? I weigh 70 kilos and planning on 28mm tyres.
Ive run much lower when i was too lazy to inflate before a quick (1km) ride to the shops but the front felt really squirmy.
I'd try about 75-ish psi front and 80-ish rear and take it from there. Experiment: see what feels right for you and the varying road surface conditions where you are.
At 65kg, on 28mm tyres, I've settled on 60 front and 75 rear after 3.5 years of downward tweaking. Well, I reached those pressures over 2.5 years and I've not reduced either in the last year.
