Yellow Saddle
- Loch side.
I'm reading up on wheels and I want to know if this means they are fast or just cool.
The super-new XXXX wheels incorporate all the innovations of recent years, consolidated in a product without paragon in terms of performance, strength, life and reliability.
The light alloy rims come from selected extrusions and are CNC-machined to optomize the mechanical specifications, they are welded rims with a ground braking surface and the spaces between the spokes are lightened by toroidal grinding.
The rim is dynamically balanced; in other words the imbalance of the mass as a result of the non-equivalence of weight between joint and valve is compensated by the extension of the toroidal grinding.
The top bridge of the rim is not drilled in the traditional way to fit the nipples, so that the use of rim-tape is pointless and the system is lightened further as a result.
I am worried that they will not complement my riding style. I ride aggressively and don't have time to dodge potholes. I need wheels that roll fast, are super-responsive and attract the opposite sex. Will these do the job?
